Sponsored by:
Sponsored by: DashLynx
Broke Power Steering adjust plate mounting bolt
Old 02-13-2015
HempForPres's Avatar
HempForPres is an unknown quantity at this point
Hi guys, I'm new here. Honestly, I'm new to car repair in general. I successfully replaced my alternator, but at the last minute as I was putting the power steering pump back in, I twisted the head off the power steering pump adjust plate mounting bolt...
It's a 10mm bolt, I know that. Can I just get any 10mm bolt (about an inch long) to replace it?
Can anyone tell me the exact size of that bolt? I checked the repair manual and it doesn't say...
2002 Civic EX
HempForPres is offline
Old 02-13-2015
mikey1's Avatar
Re: Broke Power Steering adjust plate mounting bolt
then you don't know much, cause its a 6mm bolt
mikey1 is offline
Old 02-13-2015
Wow, I hope not all the members of this forum are as rude as you are. The socket I used was a 10mm.
Old 02-13-2015
Any chance you could provide the other dimensions?
Old 02-13-2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
It's only $1.01 at the dealer..BOLT, FLANGE (10X20) - 2002 HONDA CIVIC COUPE (957011002008) Think is a standard metric 10mm x 20 mm long . .390 diameter x 1.5pitch x .790 long. Note 1.25 is fine pitch and it could be that . If handy, I would get it form him to get correct pitch and grade..probably g5. Hardware store may not be the proper tensile. Think metric is graded a couple numbers higher for same grad ( as US English system
RIPSAW is offline
Old 02-13-2015
mikey1's Avatar
cant you just measure the bolt length?
mikey1 is offline
Old 02-13-2015
I'm at work, the bolt fell through the engine and possibly into gravel under my car. When I get home, it will be dark out. It's possible the bolt is somewhere down under my engine still.
Old 02-13-2015
Thanks, but I have to have my brother drive me, and the closest place is an Advance Auto. So, I can't get to a dealer. Plus they'd probably be closed by the time I could get there (Around 6 PM)
Old 02-13-2015
RIPSAW's Avatar
Get the 10mm x 20 mm long . .390 diameter x 1.5pitch x .790 long. You can always take it back. Be sure to check by placing it on top of the other bolt to make sure # of threads is correct. Is a part of it still in hole?
RIPSAW is offline
Old 02-13-2015
It was, but I was able to remove it with a pair of pliers. I then angrily spiked it on the ground. So, who knows where it is now. Stupid, I realize. I may be able to find it.
Mikey1 is definitely correct, it's not a 10mm bolt, I looked up bolt measurements and I now realize that the *head* is 10mm, but the threads are probably 6mm (I didn't measure them).
Here's the exact part I need (labeled A). Note that the part that the top that looks like a flange is actually two washers (one locking washer, I think, and the other regular):
Thanks for your help everyone, I'm a computer programmer, so this is alien territory for me. I can build you a PC, but I am brand new to car engines, though I did work on dirt bikes growing up.
Old 02-13-2015
mikey1's Avatar
any 6mm bolt should work there as long as its not too long,
if you are in desperate need to get your car running without going to a shop, you could probably steal a bolt from somewhere else on the car temporarily till you buy another one,
that plate is only nessessary to tension the belt until you torque down the power steering pump bolts, after that it really does nothing,
mikey1 is offline
Old 02-13-2015
RIPSAW's Avatar
Sorry Hemp, had a senior moment. I when to the alternator bracket...all above I said is wrong
RIPSAW is offline
Old 02-13-2015
Hey guys just checking back in, Mikey1 was absolutely correct, it was a 6mm bolt. Didn't really matter the length, but I grabbed 3 different ones from Advance, and ended up using a 25mm length.
Thanks everyone! My car is running great! Feels good to have done it for myself.
Old 02-13-2015
No worries, I was able to figure it out! I looked up the part you mentioned and could see it wasn't the same bolt.
Old 02-14-2015
RIPSAW's Avatar
Glad you go it fixed..It is a good filling when you do. I need to quit speed reading. I went alternator bracket broken bolt...gee... Good old Mikey came thru..did you know he was the famous kid on the cereal commercial?
RIPSAW is offline
RIPSAW
11-06-2015 04:36 AM
7thgensurvivor
38
08-29-2015 11:50 AM
EdGasket
05-25-2015 01:06 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
bsmiley
04-27-2015 01:27 PM
Quick Reply: Broke Power Steering adjust plate mounting bolt
