Sponsored by:
Sponsored by: DashLynx
Crankshaft sensor question
Old 10-27-2014
himynameisdanny's Avatar
himynameisdanny is an unknown quantity at this point
nfff
himynameisdanny is offline
Old 10-27-2014
Re: Crankshaft sensor question
I went to mechanic 2 and he said whoever changed the timing belt must've messed up or damaged the crankshaft sensor.
The finger of blame is quick to point!
That's only an assumption at best.
Reading the code alone is NOT a diagnosis.
Nobody should be allowed to blame anyone until the sensor is inspected for physical damage.
If there is no physical damage and the wiring connector is still attached, then it's not mechanic A's fault or problem.
Don't you think a broken sensor would have been a problem immediately after the timing belt job was completed?
It's now more than 2 months after the fact.
Why can't it simply be a bad sensor? Or a wiring problem? Or a myriad of other possibilities, nobody can tell for certain what is wrong until someone actually fixes it.
I feel like this is mechanic 1's fault and I shouldn't have to pay for everything. Obviously I know next to nothing about cars so any input would be appreciated.
You aren't qualified to assign blame, nor decide you shouldn't have to pay.
You own both the car and its current problem.
ezone is offline
sharp66
31
06-12-2022 08:45 AM
159
07-05-2015 09:54 PM
beantech
06-15-2015 07:09 PM
juror
05-26-2015 06:35 PM
viper775
12-09-2001 10:52 PM
Quick Reply: Crankshaft sensor question
