Will THIS engine fit my car?
Rep Power: 0 Will THIS engine fit my car?
Local web ad:
http://classifieds.castanet.net/deta...-_d16/1771154/
My car: 1991 Honda Civic DX 4-dr auto (willing to chg to stick, unless I can throw away the clutch listed in ad, & just use engine)
Engine in ad (above): from a 2001 Honda Civic
My engine is tired. Good winter beater, but have no HP when go up hills. I leave a long trail of cars behind me going up the smallest hill. For $150, it sounds like a screamin' deal for me, & 2 monkeys in a mouse wheel could produce more power than what's IN my car already.
Thoughts? Advice? (Will it bolt up to MY 10yr OLDER tranny/etc?)
Please note, I am a bimmer man, I know nothing of Hondas, so your expertise & frankness is most graciously appreciated.
PS. Here's a pic or 4 of my very special winter beater (my 90yr old mother's car originally) 1991 Honda Civic DX which has the verrry rare BMW AC Schnitzer Sports option...just found some awesome OEM wheels for her ("Eileen"...as in..."Com'on Eileen" music video ....named her as I had a stream of cars behind me & song came up whilst driving UP a hill) I know there's a few pics, but I'm PROUD of her. So, whilst u peruse. please click on the ytube video & listen to the "her" song. BUT PLEASE,...SOMEONE ANSWER my ENGINE Q ! THX !!!
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1446& transactionid=1381382728-174417640&posted_by=_www.civicforums.com&youtube_v ideo_id=oc-P8oDuS0Q[/autostream]
Re: Will THIS engine fit my car?
so, you found a motor from an 01 civic? most likely a D17 and for $150?
$150 for an engine indicates something is probably wrong with it. or someone just really doesn't care and wants to get rid of it.
In short terms, No it will not bolt to your trans or go into your car.
The options you have to swap out a motor are vast, from finding another motor from the same year car (1987-1991), using a 92-95 OBD1 engine and changing your car from DPFI to MPFI, swaping in a B-series, H series, K series. depending on your goal and budget.
I would suggest reading up on swaps here http://www.ef-honda.com/ben/EFswapguide.html for starters and see what you want to do.
Rep Power: 0 Re: Will THIS engine fit my car?
UPDATE.
dude emailed me..... here it si..
I'm actually not much of a Honda guy myself so I wouldn't be able to answer that for you.
Another thing to note about this engine is that it is out of a 98 Honda civic not a 2001. I made a typo while writing it.
Keep In touch.
Daniel
so,...it looks like a '98 Civic engine....for ,y '91....
Q still stands...WILL It FIT ??
(thx for prev reply. need info....also, appears guy just wants to clean out his gargae...so.....$150?.......sounds pretty good, considering my '91 engine is TI-ERRRED.)
Advice? Thoughts?....thx in advance....
Keep In touch.
Daniel
Anyway. Thx to all for the info about whether that 2001 $150 engine will fit, which it won't. Thx, again.
Received 1,444 Likes
Rep Power: 338 Re: Will THIS engine fit my car?
erm, he is telling about the D17, for 2001 cars... you link is for an 98, which i am not sure if fits or not.
you could have attempted to check on here instead:
https://www.civicforums.com/forums/2...er-models.html
one quote there:
" All Honda’s 1991 and earlier are considered OBD 0. This means that the engines don’t utilize any oxygen sensors and have little in the way of emissions control."
following quote:
"OBD1-OBD2 Engine Swaps into 89-91 Civic/CRX
To install an OBD1-OBD2 engine into your 4th Generation Civic/CRX the following adjustments will need to be made. First, if your car has dual point injection a conversion will need to be made to port injection. All Integra's 1994 and up and Civic's 1992 and up all use hydraulic transmissions. Therefore its not compatible with 4th Gen Civic's because these vehicles have cable transmissions. To complete the swap a B-series cable transmission will need to be used or a cable-hydro transmission conversion will need to be made. The left side bracket needs to be changed to a 1990-1993 Integra bracket.
For the ECU, it is best to use the ECU which belongs with the engine. Several wiring adjustments will need to be made to make the engine run correctly.
For LS-VTEC's, CRVTEC's and other Frankenstein's it is easiest to use the ECU that corresponds to the distributor and head. There are also reprogrammed ECU's which can be considered."
so, i do believe this is not for you, a lot of work required
one quote there:
following quote:
Whachya lookin at?
Rep Power: 289 Re: Will THIS engine fit my car?
I'm not trying to give you a hard time but if your a BMW guy why are you driving a civic? Masking a civic with BMW stickers is ... pretty damn lame.
Rep Power: 232 Re: Will THIS engine fit my car?
your car reminded me of this
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1447& transactionid=1381727467-10720366143&posted_by=_www.civicforums.com&youtube _video_id=CWxgfTMLtc0[/autostream]
the car is a sh1tty 1991 Honda DX ...FOUR DOOR. ?? DUHHHHH?
Com'on...don't be an idiot.....BMW's "waste" lozer HONDAs...& if u even HAVE to post this sh1tty assed lame Q...bout a 1991...... HONDA DX ...FOUR-DOOR...with 210,000 kilometers......then u really ARE an IDIOT....
(no offense to ACTUAL ...REAL Honda owners/drivers.)
Jus sayin......
let me re...F'ing....RE -PHRASE.
this... peece o ****..albeit sentimental value (that's ALL) ......is a F...1991 ....HONDa...(there alone, one should say ....."OK, I get it")............Honda ...DX...F.....4 ....F...DOOR.... ?????
i drive this peec o **** ...to SAVE my F...BEAUTIFUL.......BMW from the Canadian elements. DUHHHHHH.
I'd rather drive the p1ss-into-the-ground OLD Honda-peec-o-****,...than my ....MINT ...Titanium-Silber.....(that's GERMAN) .....BMW E46 cabriolet-stick...thru Canadian WINTERS.....DUHHH???? I've had 3 OTHER ****-box 80's CHEVETTEs that were a step BELOW this ****-box......BUT....
......... My BMW sees NO snow...No rain...nothing. HONDAS ....LOVE the ABUSE..... taht's why the Japs...MADE these sh1tboxes?....Non???
........ DUHHH..... fuuuuuuuuuuu....(sorry,...DO NOT.... mean to OFFEND 4-DOOR ****-box owner honda owners!!.... ( ?? ) ....but.......I LOVE driving my 30-yr...****-winter-beater-mobile .....1991 into the GROUND....that's what they r for?...NON?? ...........)
did you check my post?
the answer is there in more detail.
and don't get too hot, this is internet after all
(prolly Tom was drunk when he wrote that too :P)
Whachya lookin at?
Wow that was an intelligent post. Nope, wasn't drunk Sandro. I just don't see why people slap BMW stickers on their cars that clearly aren't BMWs. Does the BMW sticker somehow make the 91 POS car any better? To each their own I guess I just find it kinda lame. Just drive the POS beater that many others drive as a DD and enjoy your BMW. Since your too good to drive a Honda like the rest of us.
r u a f ....IDIOT ?
Jus sayin......
Jus sayin......
the answer is above, me believe he's not really a troll, otherwise he would not have typed what he did above...
he took caution to not to offend other members, made clear that sh*tbox or not he likes the car as is, so no, don't think he is troll. might become for the warm welcome, tho...
cheers!
reviving my old thread....cuz...I ,...well just love my cheap POS ...it just keeps on going...like the Energizer Bunny. I'm always on the look-out locally for other 91 Civics cuz they are the BEST cheapest, reliable, but boring POS out there to use as winter beaters. Do not mean to flame...cuz I'm REALLY proud of my Civic. srs.
Anybody in the Penticton area (BC) who want to sell their 91 Civic?
I jus bought an absolute .... TWIN ..... to my winter beater. Same color, etc.....but the A/C...actually works!!! My ********* retract into my groin, maan. Imagine. TWO white/blue EXACT DX's in my driveway. Plan: to go buy some BLUE dingle ***** for Honda #2, so I can tell'em apart.
So I didn't catch it in the beginning of the thread, but you're 16 years old right? Does the BMW let you park in the handicap spaces? That's about the only reason I'd drive one.
I, possibly like you and some others on this forum, am a hard working, well earning individual that is blessed enough to own (me, not the bank) $100k cars but that doesn't mean I would ever talk down on any of these helpful people or what they drive/do. Don't be the elitist ***** that everybody thinks you are. Play nice.
Congrats on the twin.
Received 1,149 Likes
Rep Power: 485 Re: Will THIS engine fit my car?
Saw a bunch of posts pop up from you, and seeing your username, immediately thought, "not another troll on our little Honda forum...."
However, reading your posts, they've been quite colloquial, helpful, and respectful. Thank you, and carry on.
Lol the username is used universally so that I'm not trying to remember a bunch of forum-specific names. I joined this forum specifically because I work on a civic within the family so I understand that it (the forum) will mostly benefit me in the long run with information and support. The least I can do is try to help others wherever my knowledge allows.
CarStuff
12-06-2020 12:52 PM
aus10
04-13-2015 09:26 PM
