cylinder #3 intake valve
Rep Power: 0 cylinder #3 intake valve
hi guys, quick question, im doing a headgasket on my 2005 honda civic 1.7, i got the head removed and i notice that cylinder #3 intake valve is open(just one) is this normal?
i got all the timing mark lined up before removing the timing belt.
really appreciated your answer thanks in advance
ed
ed
Re: cylinder #3 intake valve
Ed
When I go to reinstall the head can I just realign the marks or is there an issue of maybe getting it 180 out? Thanks.
You can't get it "in time" and be 180* out..
Rep Power: 0 Re: cylinder #3 intake valve
thanks for the reply, what is did is just tear it apart and put the new headgasket . my cylinder was in good shape. i did really get oeverheated all the way to H. i just notice that my temp gauge goes up. that when i notice there a problem. i search every where about the 7th gen and all in came to headgasket problem. coolant is going to resevoir. i took it apart monday and just finished it today, so far so good. This is actually my first time to take honda engine apart. i've done infiniti short block. this engine is so easy. just make sure you line up all the mark top and bottom.
Addn't to my question.
i got my scanner shook up. what is the set IGNITION TIMING?
so far so good. i drove it for ten miles and did not get any coolant over flowing from the resevoir.
NoobyKid
07-13-2015 07:53 AM
CivicsClass101
07-09-2015 11:14 AM
