Sponsored by:
Sponsored by: DashLynx
O2 sensor
Old 08-15-2012
thewal's Avatar
thewal will become famous soon enough
O2 sensor
good day all,
Looking to replace my primary O2 sensor, and i am wondering if there is a preferred brand to go with. I was looking at the NGK. what does honda use?
Can anyone assist please.
Thanks
thewal is offline
Old 08-15-2012
Prelude Owner
GolNat's Avatar
Re: O2 sensor
Only use NGK or Denso! Never Bosch! Idk which is OEM but both are good.
GolNat is online now
Old 08-15-2012
thewal's Avatar
Re: O2 sensor
Thanks.
thewal is offline
Old 08-16-2012
scooty's Avatar
scooty is on a distinguished road
Re: O2 sensor
I just replaced mine with an OEM from Honda parts now for like $58.
I couldn't find any parts shop in my area with the correct part in the right box.
scooty is offline
Old 08-16-2012
thewal's Avatar
Re: O2 sensor
Parts in the states are much cheaper, dealer o2 sensor here is $200 Canadian.
thewal is offline
Old 08-16-2012
Prelude Owner
GolNat's Avatar
Re: O2 sensor
Damn that's a lot!! I've heard that car parts are more expensive in Canada. Its probably not much cheaper to order it online after shipping charges. The o2 sensors for 03-05 are more expensive then 01-02 because they are narrow band instead of wide band.
Old 08-16-2012
I am Epic
Civicnoobie's Avatar
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
Re: O2 sensor
Am i ok waiting til mine goes bad before replacing? I just hit 100k miles and no engine error codes
Civicnoobie is offline
Old 08-16-2012
Prelude Owner
GolNat's Avatar
Re: O2 sensor
Yea you can wait until it goes bad. I'm at 155k with mine. If you want to help your mpg then you can change the 02 sensors. I was thinking about doing mine just for that reason. Over time they loose accuracy and get all grimy.
Old 08-16-2012
thewal's Avatar
Re: O2 sensor
that's why i am changing mine.
thewal is offline
Old 08-16-2012
lowlife9's Avatar
Re: O2 sensor
meh i picked up up a DENSO oem replacement wideband for 90 dollars at advanced auto of course the dealer wants 200 dollars. why would you pay $200 for dealer sensor when the identical plug is $90 at a parts store ???
lowlife9 is offline
Old 08-17-2012
thewal's Avatar
Re: O2 sensor
I replaced mine this morning and compared the 2 they where identical both made by NTK.
Dealer wanted $200 for the part I got it for $50 at a local parts store.
thewal is offline
Old 08-17-2012
Prelude Owner
GolNat's Avatar
Re: O2 sensor
Good deal! Any improvement in MPG's?
Old 08-17-2012
thewal's Avatar
Re: O2 sensor
I only replaced it this morning, i will keep you posted as the weekend goes by.
thewal is offline
BootyDo
06-21-2016 03:45 PM
Green02civic
07-27-2015 10:48 PM
Dani1993
07-24-2015 09:02 AM
mistermenphis22
07-13-2015 04:43 PM
Quick Reply: O2 sensor
