Sponsored by:
Sponsored by: DashLynx
2002 Civic EX Thump on Drivers Side Floor
Old 04-30-2012
mgslayer's Avatar
mgslayer is an unknown quantity at this point
First time poster, frequent reader.
I have a 2002 4 dr Civic EX 5 spd with 136K miles that started making a thump that I can feel under driver's side, almost directly under my feet when moderately accelerating. Some days are worse than others. I have since replaced both lower control arms because the rubber was shot, front sway bar end links, front sway bar bushings, front motor mount (torn to shreds), drivers side motor mount, and rear sway bar bushings. Rear trans mount looks to be solid. I didn't replace the rear sway bar end links because I ran out of daylight, so that is on this weeekends plans. Anything else I should check? Lower ball joints were loose but not sloppy, and no extra slop in the wheel bearings.
Thanks
Mark
mgslayer is offline
CarStuff
12-06-2020 12:52 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
ej8
04-13-2015 06:36 PM
CapYoda
11-11-2001 05:17 PM
mwwhonda
11-07-2001 07:24 PM
Quick Reply: 2002 Civic EX Thump on Drivers Side Floor
