Car Audio Question
#31
Rep Power: 0 Re: Car Audio Question
My sub amp is actually a 600W RMS, so I have the gain turned WAAAAAAY the hell down and I don't push it. The way I have it setup tho, it adds a nice bass accent instead of overpowering like I've heard in many other systems. Enough bass to notice I have a nice system, not enough to make you wanna stab your eardrums. I have played with it a bit tho, cautiously turning it up so I don't kill the sub, and it performs nicely.
And the box you're building, I actually had my old sub in that spot. an Alpine type-r 4-ohm 10". Made a fiberglass box just so I was able to get the experience with fiberglass, and so I'd have enough know-how to attempt it again if I so desired.
#33
yea man i feel you on the budget thing i only managed to afford this set up since i was an installer for a few years and worked for jl at one point in my life. so got some great discounts on them.
here is a link to the jl system hat i designed and installed in my friends s2000 and the carbon fiber stuff too. http://s1024.photobucket.com/albums/...%20on%20S2000/
#34
Kenny the Ricer
AK?
I think i'd step it up, and whip out the AT4.... :P
And I'm currently still running my W3 on an Xplod amp, so I think you can feel my pain a little...
This guy offered me a M600/1 for.... $300!!! Completely brand new in box, not even out of the wrapping yet
I almost had an impulse buy, but no. I was smart, I purposely didn't bring any money to tempt myself.
#35
Hey guys.. I'm not going to put in the RE 12's or the JL 15
I just baught a DC level 5 12 in a ported box.. The box looks to be small enough fo fit behind my driver or passenger seat instead of the trunk. I kinda want to put it behind my driver seat just because I think I would get a lot better sound and eliminate trunk rattle without having to spend more money for dynomat...
What do you guys think?
#36
#39
Kenny the Ricer
I havent had the funds to sound deaden my car yet...
But if i do, it will be second skin
I will try to do a distance test with my sub sometime this weekend, if you want to wait that long, I havent really heard my car's outside much, but the bass response inside is tight and nice (mind out of gutter)
Main rattle is mostly license plate, but dynomat sells license plate deadener kit for about $10
#40
dont put all three subs in the car.. period... seems to be alot of misunderstood facts being thrown around on this thread.. placing different size drivers in your car is like placing differenct size tires on your car.. ya it will still drive but you sacrifice handling and efficiency.. i would definitly do the dual 12s in a slot ported box with the port vented out the top of the rear parcel tray... now that being said if you really really want to run all three then you will have to use the 15 xover from 50hz down at 36db/oct. in a sealed box, then use the 12s placed upfront somehow running from 63 hz to 800hz with an agressive slope on the lp and very aggressive on the hp... now the tweeter will have to play extreamly low so your options are really limited.. i would recommend a tang band 2514 ceramic tweeter it will play down to 800 hz but xover must be 36db/oct.. now that being said, you now have to run some delays to get the midbass to blend nicely with the tweets so i would recommend getting the pioneer dex-p99rs head unit, does everything, not cheap but does everything... man its alot of work to make those subs work just ditch the 15..
#42
Ok, this is my current bass set up in my 03 Civic EX. 1 DC Audio Level 5 12in sub in ported box powered by a 3000 watt SPL amp which is hooked up to a 2400 watt Kinetik battery.
My goal is to have loud bass but as little 'rattle' as possible. I just dynamated the trunk but the dynamat does not help the rattle comeing from the trunk latch. Standing outside of the car, I still hear tons of rattle.
So I came up with an idea similar to this. Except without the leather slide and plexi glass over the sub to protect the sub when I have backseat passengers.
I got this priced yesterday and the guys told me it would cost about $600-$800.
Do you guys think this would increase the bass inside the car and eliminate most of the rattle? What do you guys think of this idea? If anyone has anything similar or seat deletes please post a pic!!
Thanks in advance!
Thanks in advance!
#43
Kenny the Ricer
Sorry I forgot to post my distance test
Here is my vid:
Video recorder not the best at capturing sound, but if you have a computer sub, or good headphones, you'll prolly hear it good enough
Keep in mind this is only 280 RMS and volume at 18/35 (which i typically listen to)
And those speakers are powered by head unit alone, no amp
[Youtube]http://www.youtube.com/watch?v=tzAnDSQYROA[/Youtube]
PS.
Are you only running your car on that single Kinetik battery?
I hope not
Kinetiks are power cells, not starter batteries.
Also, if it's only $500~800, go for it if you have the funds, looks nice, Dont know if it'll do much for the rattles though
I'd rather spend $200 to fully sound deaden the car
Here is my vid:
PS.
I hope not
#44
Kenny the Ricer
Definitely too late if you've already bought speakers, but most coupe owners should know, rear speakers kill the sound stage inside the vehicles, and if you don't have speaker baffles on those rear 6x9's, you might as well be stabbing them with forks.
That sub will eat those speakers alive.
And if you're looking into a new sub carnoobie, I'd look into the JL Audio TW5, slim mount sub, but heavy hitter.
Heavy price tag too though.
I was thinking about adding 1" tweeters, or 3" speakers on my rear side panels, it'd be a nice addition, but I dont know if i got the guts to drill into my panel lol
Also, I've gotten all but a couple rattles in my coupe:
The trunk floorboard, and the headliner of the roof
Floorboard i plan to MDF that sucker, and headliner should be a quick fix, just been too lazy to do so
#45
Finished
#47
Rep Power: 0 Thread
cloudguy
04-28-2015 05:02 AM
