Sponsored by:
Sponsored by: DashLynx
2005 Civic air conditioner issues
Old 08-26-2010
TManiac's Avatar
TManiac is an unknown quantity at this point
Hi all-
Glad I found a place online to ask questions about my car, hopefully you guys can help me out.
I live out in southern CA and lately temps have been hitting up 110 degrees so my serious lack of a decent air-conditioner has made my commute absolutely miserable.
It takes about 15-20 minutes of driving with the engine revs above 2500 to even start feeling cool. If I'm stuck in traffic the AC never cools down.
Ive got about 110,000 miles on my civic and as far as I know the AC has never been serviced. Also the fan is really s****y. When its going full blast I can barely feel the air blowing on me.
So I have a few questions-
-Does anyone else have similar issues with their '05 civics?
-Will recharging the system help much? (I don't want to go spend $90 and not have any significant improvements)
Any advice would be much appreciated
-TManiac
TManiac is offline
Old 08-26-2010
Re: 2005 Civic air conditioner issues
have you tried changing the cabin filters behind the glove box? sounds like you have an air flow issue. if the blower is loud like it should be at full power, then the filters are clogged. should be changed every year max. most a/c systems will not help much in hot weather when the car is already warm to start with. does the air feel at least a little cold to the touch? or is it warm like no a/c. also if you turn the recirc air button on, it will blow harder.
gearbox is offline
Old 08-26-2010
TManiac's Avatar
The air does feel cold to the touch. It just takes a while for it to get to a comfortable temperature.
I didn't even think about the cabin filters. That definitely makes sense. I doubt they have been replaced in the 5 or 6 years this car has been on the road.
Thanks for the advice! First chance I get I will definitely replace the filter. Even if thats not the issue it probably needs to be done anyway.
-TManiac
TManiac is offline
Old 08-26-2010
lazlong's Avatar
Yeah, cabin filters. Went about 50K before I change mine the last time and it was like a whole new system. Also found a mummified gecko too. lol
lazlong is offline
Old 08-27-2010
TManiac's Avatar
Changed the cabin air filters today. They cost 20 bucks and took like 3 minutes to change. The old filters had about a quarter inch of dirt/bugs/dry leaves and other crap in between the filter element.
Ive never felt the air blow this hard before so it was definitely worth it. The a/c is still weak though. I'll get it recharged one day. Thanks for the help
TManiac is offline
Old 09-20-2010
johny2392's Avatar
johny2392 is an unknown quantity at this point
pardon me but can someone tell me where is this cabin filter located in 05 civic?
My AC is pretty much OK but i have no idea about this cabin filter thing.
johny2392 is offline
Old 09-20-2010
Camden's Avatar
Camden is an unknown quantity at this point
I know on the 04 civic the cabin filter is located behind the glove box. You remove your glove box (quite easy) and there should be plastic slider cover. You slide them and just pull them out. It's quite easy.
Camden is offline
Old 09-20-2010
lazlong's Avatar
My finger is on the cover lever:
lazlong is offline
Old 09-12-2014
redge3sa's Avatar
redge3sa is an unknown quantity at this point
need help with my 2005 civic hatchback, my a/c just stopped working. and the pump doesn't sound like its turning on. what can I do to troubleshoot issue?
redge3sa is offline
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
civic_gt
04-19-2015 08:15 AM
dano2005
04-14-2015 01:58 AM
Quick Reply: 2005 Civic air conditioner issues
