2001 Civic Suspension- FED UP!!!!!!!!!!
Rep Power: 0 2001 Civic Suspension- FED UP!!!!!!!!!!
Changed shocks, nipples, LCA, Strut mount and today I changed my rack ends...and still getting a knocking/rattling at the bottom left of the front suspension..........I am tired....really tired!!!!!!!!!!!!!!!
PLEASE HELP!!!!!!!!!!!!!
Received 1,442 Likes
Rep Power: 787 Re: 2001 Civic Suspension- FED UP!!!!!!!!!!
the metal pieces that hold the sway bar to the LCA. it can rattle bad if theyre broken. these are moog parts, your oems will be smaller and different looking. but same idea.
Rep Power: 0 Re: 2001 Civic Suspension- FED UP!!!!!!!!!!
my 03 civic was making a really bad clunking, rattling noise when i would coast but not when i was on the gas for some reason.
brought it in to get looked at and found out it was the sway bay links.
sounds like you're having the same problem as i was so these guys might be right.
yeah different name for the same part. check the rears too if you have a bar back there. if you have suspension upgrades (lowering springs), those factory links will keep snapping.
yeah each bar has two bushings and holders. if they are torn, you could get metal noises from the bar touching the holder.
hey, I went to another mechanic today and the noise has been reduced significantly...he did something to the left side strut mount and the noise has disappeared....there is a small noise on the right side which he committed to fix tomorrow
Rep Power: 338 Re: 2001 Civic Suspension- FED UP!!!!!!!!!!
But you had changed the strut mounts before, right? installation issues then?
i wonder if he just sprayed some silicone lube, in which case the noise will start coming back a few months later.
mattdoc
03-14-2017 12:10 PM
CapYoda
11-11-2001 05:17 PM
Lightman
11-10-2001 06:44 PM
