Sponsored by:
Sponsored by: DashLynx
How to make a Cam Lock Tool from Harbor Freight's Serpentine Belt Kit 66344
Old 09-09-2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
I needed a cam lock tool to work on a V6 Avalon soon and discovered that the cheap ones sell for just under $70 on Amazon. When I read the reviews I learned that everyone that worked on the V6 Yota engine complained that the tool bent because it was aluminum and not strong enough. I was able to make mine for under $20. It works on my Honda, as demonstrated in the video, and I will find out if it works on the Yota. I hope this helps others. I am quite proud of what I made and I have not found anyone else on YouTube or Google to have created this tool from Harbor Freight's existing tool. I am assuming I am the first.
OptimisticWay is offline
Old 09-09-2015
Re: How to make a Cam Lock Tool from Harbor Freight's Serpentine Belt Kit 66344
Here is the HF item:
http://www.harborfreight.com/serpent...kit-66344.html
And here is where you can get a 20% off coupon or sometimes a 25% off which is rare, they only come out on holidays now:
http://www.dealsoff.com/harbor-freight-coupons/
Old 09-09-2015
Prelude Owner
GolNat's Avatar
cool tool. That will definitely make the job easier.
Luckily the last time I removed a cam gear just jamming a drill bit in a slot and between some other pieces was enough to get the bolt loose.
GolNat is offline
Old 09-09-2015
Thanks. On the Honda D's the torque is somewhere in the low 30's to upper 20's so yeah not hard. I have done it with the belt on. The Toyota1MZ-FE engine takes in the neighborhood of 60 foot pounds I believe.
You can see how hard this guy struggles with the tool and a long breaker bar. The bolt on my D series head is a 12mm. The Yota is a 17mm which can and does take more torque.
Okay, this video was supposed to start at the 18min 26 second mark. Since it didn't, start it on that point for the tool.
Old 09-18-2015
I finished working on the 1MZ-FE 3.0L V6 Toyota engine two nights ago and I am PROUD to say that the tool held up to 92 ft lbs of torque. These camshaft pulleys require 92 ft lbs of torque after installation.
I love it when a plan comes together.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
slynger
18
05-08-2015 06:06 PM
bsmiley
04-27-2015 01:27 PM
thesushiboy
04-12-2015 07:40 PM
nymbus2k
11-19-2001 07:01 AM
Quick Reply: How to make a Cam Lock Tool from Harbor Freight's Serpentine Belt Kit 66344
