P0428 Code
Rep Power: 0 P0428 Code
My check engine light has been on for a few months now, however it hasn't made a difference in the performance of my 2005 Honda civic lx. My local mechanic scanned the code and told me it was p0428 and most likely my catalytic converter needs to be replaced. I've been browsing the forums and i've read it could possibly be a faulty o2 sensor... I'm not sure whether to spend 1K on a new cat or try replacing the o2 sensors? Any advice or input is greatly appreciated! Thanks!
Received 1,450 Likes
Rep Power: 339 Re: P0428 Code
compare prices and check the least expensive - both will get some 3 digit figures, unfortunately, since 2005 uses wideband o2 sensors
no way to know which one is the culprit? unless ezone knows a trick on that, wait for his input?
Re: P0428 Code
One way to test the cat is using an infrared thermometer gun and measuring the temperature at the inlet and outlet of the cat while car ideling at normal operating temperature. If the temperature at the inlet is much higher then at the outlet then the cat is clogged
Re: P0428 Code
The code can't be P0428, it's probably P0420. Cat efficiency below threshold.
There is nothing in the P0420 code definition about O2 sensors or A/F sensors being bad. There are a ton of other codes available specifically for those sensors.
IOW, you will only waste money replacing sensors needlessly.
Trust the code.
Re: P0428 Code
Probably.
I'd also want to make sure I know why the cat has failed, and I'd want to make sure there aren't any exhaust leaks between the head and the cat.
Civic15
18
09-19-2017 07:48 PM
Dangerousjordan
07-30-2015 11:19 AM
jessica19699
07-29-2015 05:51 AM
Green02civic
07-27-2015 10:48 PM
