Bardahl power steering fluid = oem?
I am Epic
Rep Power: 0 Bardahl power steering fluid = oem?
I was at honda the other day getting paint and the parts guy didnt have any PSF but he said he tells people we can use the bardahl one which is the exact same fluid. Is that true?
Did a search on bardahl and heres a link i found
http://www.bobistheoilguy.com/forums...&Number=997677
bardahl PSF is ok to use?
Another thing he said is if i had any honda atf on me, i said yes, and he said i could use that too because its the same. He said honda atf and honda psf is the exact same minus the dye (and the dye wont harm anything)
Is this true? Use honda atf?
Whachya lookin at?
Rep Power: 289 Re: Bardahl power steering fluid = oem?
Umm.. this used to be true pre-1990. Nowadays though, power steering fluid has a different checmical composition than ATF. The mechanic is probably old-school. I'd use this if you want bordahl:
oooops
oooops
Most honda fluids are made by Idemitsu Lubricants of America (www.ilacorp.com). That includes ATF, PSF, Oil, Differential Fluid, etc.
Honda DOT brake fluid and Type 2 Coolant (Antifreeze) is made by CCI Manufacturing IL (www.cci-il.com).
The ATF is not the same as the PSF (!), and it is not guaranteed to be the same as any aftermarket (Bardahl, Valvoline, or anyone else who makes a "Honda" PS Fluid).
Rep Power: 788 Re: Bardahl power steering fluid = oem?
seems legit, however the part about having stop leak additives makes me nervous
http://www.oreillyauto.com/site/c/de...0493&ppt=C0175
Received 1,451 Likes
Rep Power: 339 Re: Bardahl power steering fluid = oem?
looool!
mattdoc
03-14-2017 12:10 PM
RIPSAW
11-06-2015 04:36 AM
7thgensurvivor
38
08-29-2015 11:50 AM
vvr210
05-31-2015 08:02 PM
