10 Year Old Black Paint Restore
Rep Power: 0 10 Year Old Black Paint Restore
I'm trying to sell my girlfriend's Black 02 EX but first it needs/needed a TON of work including functional and also cosmetic stuff. I'm now focusing on the paint and noticed yesterday that it is dull and hazy. Based on how much she abused the car in every other way I am guessing it hasn't ever seen a wax job. We live in Detroit where salt is definitely an issue.
What can I do that is easy and inexpensive to at least decently restore the paint?
Rep Power: 0 Re: 10 Year Old Black Paint Restore
Okay, yeah, that was my first and only thought but I figured there might be either an additional step or an alternative method that would yield better results.
Is the claybar method appropriate for this kind of job? Specifically for 10 year old, dull, hazy paint?
I'm wondering if the haziness is a result of the clearcoat having been degraded and now the paint underneath is actually degrading. I'm wondering if now that it's gotten to this point there is no solution that will help except to fully repaint. If that's the answer then I'll know not to waste too much time with it or at least not to expect much...
Rep Power: 787 Re: 10 Year Old Black Paint Restore
meguiars ultimate compound followed by ultimate wax. will bring the color right back.
I usually use the Turtle Wax brand.. i cant remember which type it was last.. but is this Meguiars stuff better? my car is the navy blue metallic lookin color and i just want it to "sparkle" again. and also, from being in the garage, and having people passing by, there are a few scratches on the doors.. does this Meguiars help that at all? cuz i know the turtle wax just leaves the scratches looking worse.. with the white wax just filling them in.. anyways, any advice helps, so thanks!
meguiars ultimate wax was made for metallic paint finishes. made my silver look like someone sprinkled glitter all over it lol
Rep Power: 232 Re: 10 Year Old Black Paint Restore
Meguiars Ultimate Compound is a really good product i just finished a full detail on a friends 1990 toyota pickup that sat for years it brought the shine back no problem just make sure to pick up an orbital buffer they sell then at harbor freight tools for $20 dollars they also sell a foam buffing pad kit that i would recommend if you have no experience will buffing machines. if she has alot of chips and road rash get a paint repair kit from Dr color chip http://www.drcolorchip.com/ . then finnish up with Meguiars new ultimate wax.
sweet ill have to check em out then.. turtle wax just didnt seem to do nothin last time i used it, so definetly time to change products and i am gonna go with the Meguiars brand. I used to have a black, non metallic, color car and turtle worked on it, but then again, there were no shiney pieces like i have now.. so i'm prayin this stuff makes it look like "glitter" in my paint
One more question... should I wash the car with detergent or something before starting in with the ultimate compound? I know detergent strips off wax etc. but i figure that might not be a bad thing since I'm building up a layer of wax right after.
i would use some form of auto soap. not a fan of using detergent on any car. i use armor alls new soap now, but just something like that. i'd stay away from detergent for sure tho.. just my 2 cents
Before waxing I would use dish detergent such as Dawn to wash the car. Dawn will strip/remove any old wax to prevent buildup. After waxing only use a car wash soap made for washing cars. Most companies that make wax also make a wash.
Rep Power: 210 Re: 10 Year Old Black Paint Restore
I've used hand soap/water on cases like this before. Just use your judgment, you're looking for it to be a clean and dry as possible.
* For heavens sake, don't use a pressure washer.
* When using the buffer on old or beat up paint start with a very small place that's not real noticeable just in case it takes the paint off. If it does you're gonna have to do it by hand. (You'll have to go over it by hand after the buffer anyways.)
When you wash the car use an old bath towel, the thicker the better. The goal is to get the dirt and grit away from the paint so that it doesn't leave scratches. A towel will let the dirt move up into the nap and away from the surface. Stay away from sponges, they rub the dirt into the paint.
foam pads won't burn the paint if you leave it in one spot to long like wool.and black cars are the hardest to work on plus you just using a light compound so foam is best if your were getting heavy scratches out wool would cut better . and yes always wash your car before any kind of buffing you could also clay bar for even better results.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
But as for 10" foam pads that are compatible I am lost... I have an orbital sander that is like 6" or so and has variable speed which uses a velcro system but I'm thinking that's not preferable. I'm such a noob but please help.
Okay I've decided my plan of attack... I'm going to buy a Porter Cable 7346 from Lowes - http://bit.ly/jpKqaF (fortunately they have a nice return policy if I decide I don't have a use for it after using it for this project). From what I understand it comes with a velcro backer to allow for velcro pad compatibility. I'm going to pick up one or two of these:
Meguiar's Soft Buff 6.5" Foam Polishing Pad
Meguiar's Soft Buff 6.5" Foam Finishing Pad
Meguiar's Soft Buff 6.5" Foam Cutting Pad
though I really don't know which or what I should use or how many I'll need. I'm going to wash with Dawn (more specifically the crappy off-brand **** my cheap gf buys) first then use Meguiars Ultimate Compound, then use Meguiars Ultimate Wax. I"m guessing I'll use a cutting pad to apply the ultimate compound first, then let it sit and buff it off with a polishing pad. Then after it cures or whatever I'll apply the ultimate wax with the cutting pad (maybe after washing the pad???) and again buff that off with the finishing (or polishing) pad.
That's it I think?
That's it I think?
Whachya lookin at?
Rep Power: 289 Re: 10 Year Old Black Paint Restore
I think actual dawn has a special agent in it that removes wax. I remember reading that so I'd wash it with actual dawn not the cheap off brand I could be wrong but that's what I remember reading.
you dont let compound sit you apply to the pad then immediately start buffing. you only let the wax haze up then use a micro fiber cloth to remove it by hand not with the buffer only use very light pressure because micro fiber will scratch if you use to much pressure . there are a ton of miguires DIYs on youtube i suggests you watch them.also you should apply the wax by hand in small circular motions the miguires wax kit will come with a foam application pad.one more thing dont get any compound or wax on any black plastic its a bitch to get off if it dries.
I accidentally messed up the color of the trunk lid. I have a black civic. There were many scratches and one HUGE scratch across it (all due to the previous owner), so I tried to "sand, primer, paint, overcoat." Let's just say that it did not blend well. Now I need to repaint it professionally. So I decided to just paint the whole car to get a uniform look.
usajags84
15
08-19-2015 03:12 AM
stryder12
06-30-2015 08:33 PM
