Sponsored by:
Sponsored by: DashLynx
oil advice
Old 09-12-2014
petept's Avatar
petept is an unknown quantity at this point
oil advice
Hi everyone, im about to change my oil,2001 honda civic,152,000, no leaks, no burning. 20 mile daily commute to work,%70 city driving. Previous owner did quaker state dino 520 every 5,000. I would like a better oil. Is it to many miles for synthetic? Is a high milage oil bad cause I have no leaks? Just confused as what to use? Thanks for any input you may have, you all are so helpful..Thank you
petept is offline
Old 09-12-2014
Stock 99's Avatar
Re: oil advice
https://www.civicforums.com/forums/1...ters-more.html
https://www.civicforums.com/forums/1...er-change.html
https://www.civicforums.com/forums/1...ge-engine.html
http://www.bobistheoilguy.com/
Why bother trying to fix something that isn't broken?
Stock 99 is offline
Old 09-12-2014
mikey1's Avatar
Re: oil advice
Hi everyone, im about to change my oil,2001 honda civic,152,000, no leaks, no burning. Previous owner did quaker state dino 520 every 5,000
why not just stick with what is working?
i have been using quaker state since the day i bought my 05 brand new, my engine doesnt burn a drop and doesnt leak a drop, sounds like the previous owner treated the car very well,
why are you trying to fix what is not broken? stick with the same oil, its doing just fine, you are just wasting your money with something else, your chances of an oil related failure in these engines is zero,
use the same thing the previous owner was using, if its not broken, dont fix it, frequency is more important then quality....expensive oils are a waste of money
mikey1 is offline
JohnnyBxo
11-12-2015 03:04 PM
jody501
07-10-2015 11:01 AM
jzhartman
07-09-2015 04:56 PM
CivicsClass101
07-09-2015 11:14 AM
Quick Reply: oil advice
