Sponsored by:
Sponsored by: DashLynx
place to buy a dome light cover..?
Old 09-27-2009
tinnguyen123's Avatar
tinnguyen123 is an unknown quantity at this point
does anyone know a place i can buy a dome light cover..? i try ebay, so im guessing pepboys probably dont have it..
my dome light kinda snap off and broke on the side because i was angry at it
also if anyone have an idea of how to make those dome light REALLY clear..?
tinnguyen123 is offline
Old 09-27-2009
Re: place to buy a dome light cover..?
just gotta buy the whole assembly off ebay. i see em there all the time.
gearbox is offline
Old 09-27-2009
unTuned's Avatar
if youre asking if theres a way to make the dome light cover more clear, i dont think so. its a foggy plastic. if you really want to try go do the same procedure you see in the diy of the headlight lens refinishing for foggy old headlight lenses and it might help but i doubt it.
unTuned is offline
Old 09-27-2009
well i was googling and i ran across an idea about going to a Salvage junkyard to pry one out..
oh i just tested something with the dome light cover.. it NEEDED to be foggyish or else the light won't spread out enough.. i try to remove the dome cover to see the difference..
the LED light i have was REALLY bright.. but its at an angle.. that cover helps it spread the light out =D.. so i guess i wont be needing to get a clear one..
Old 09-27-2009
CraigW's Avatar
Investigate these part #s
34251-S5A-003 = Sedan (center dome light cover)
34251-S5P-A00 = Coupe (center dome light cover)
CraigW is offline
SoyerOner
05-11-2015 09:46 PM
twtron
04-17-2015 12:09 AM
shaejb15
04-12-2015 11:38 AM
meels808
11-05-2001 09:15 AM
TropiKalCiviC
09-25-2001 07:02 PM
Quick Reply: place to buy a dome light cover..?
