Ricochem OEM coolant
"Honda - tried, true & tested...!"
anyone use Ricochem oem coolant in there 8th gen civic?
Ricochem claims its fully compatable with (Hondas Acuras & Subaru"s)
blue coolant..?
blue coolant..?
Re: Ricochem OEM coolant
anyone use Ricochem
oem coolant
blue coolant..?
blue coolant..?
Which of their (Ricochem) many different coolants are you going to compare with?
I couldn't even find anything about 'Ricochem' when I googled it the other day...I found Recochem if that's what it was meant to be. I also didn't see anywhere on their website that it specially said anything about Honda compatibility (and they do name some car manufacturers). I just changed my coolant 2 days ago because it was at the 3 year maintenance period. It cost me $25 from Honda (which I do think is expensive) but it lasts for 3 years so not much at all in that sense. People are alway free to use whatever they want....I do get tired of people wanting to save $10 vs using proper fluids though.
my 2 cents (oh wait pennies are a thing of the past now).... my 5 cents
Googled as per the OPs spelling, and I see he asked the same question elsewhere. http://hondaforum.com/forum/showthread.php?t=9187
So I go to this page: http://www.recochem.com/en/products/automotive_liquids/category/antifreeze_coolant/
When I read this line: "Recommended for use in all makes and models of foreign and domestic passenger vehicles and light duty trucks"
I already know that statement is bullpoop, because the only one that says this is the manufacturer of this product.
Absolutely directed at the consumer market.
BUT the individual pages do have a shopping list of specifications, for those that wish to actually do the research.
I don't have Hondas specs though. Here's all we get
Blow up this huge pic of the back label on a Honda coolant jug
http://i.stack.imgur.com/65Ebb.jpg
Front label
http://www.hondapartsdeals.com/image...OL999-9011.JPG
Hondas Type 2 coolant says it's
Conventional Ethylene Glycol
Non-Silicate
Non-Borate
50% Deionized water
ATSM D-3306, ATSM D 4340
Proprietary inhibitors NJTSRN217 (Google NJTSRN with and without the number)
Then I get to this page:
http://www.recochem.com/en/products/...reezecoolants/
I like this more. Seems as though they really are an OE supplier to the manufacturer with these products.
I'm going to guess you will not find these in the fluids section at your local Pep Boys or DangerZone or whatever you have up there.
I'm assuming "OEM" is a brand name (designed to capitalize on the acronym) here, not an actual acronym.
DangerZone likes to sell parts by that name here.
There are people out there that are far more up to date on coolant tech than I am. I'm just a user.
Received 1,443 Likes
Rep Power: 338 Re: Ricochem OEM coolant
Lol! Most will not even get the penny exchange stuff between you two!
mispelled it correct name is Recochem coolant" im debating on using this
coolant because after all Honda does say in the owners manual using any
other coolant other than (Honda"s type2 can cause corrosion) Honda will
never specify whats exactly in there coolant so for that reason I think
theres always going to be copy cats that claim theres is as good as OEM.?
Is there something wrong with getting Hondas coolant?
It's practically guaranteed to be the correct product for your application.
EDIT: Did you google NJTSRN ?
EDIT:
Honda will
Op, if you check the manual transmission fluid, you will find out even more quirks Honda specific fluids
PS fluid, Dual Pump rear diff fluid, VTM4 rear diff fluid, the list goes on and on.
It used to be so simple, any idiot could dump fluids in and get it right.
Now, not so much.
Fluids are application engineered nowadays.
liagreenhalgh92
07-21-2015 01:31 PM
hayden55
07-08-2015 11:38 PM
hatch90
07-05-2015 01:17 AM
