8th Gen 2006 - 2011.
2009 LX with 160K...200K maintenance suggestions?
Old 01-22-2012
Gobuckeyes97's Avatar
Gobuckeyes97 is an unknown quantity at this point
I have a 3 1/2 year old 2009 civic LX with a whopping 160K miles (purchased new) and plan on being over 200K in a short time. The car is solid and everything works. Amazingly, call me crazy, but this car runs as it did brand new and I've replaced only the brakes/filters/fluids/battery.
What maintenance should I perform on this car now or at 200K? The only things I have ever done to this car are as follows:
oil/filter a billion times
battery
front rear brakes
air filter a few times
tires (of course)
I believe that's all I've ever done. It runs perfectly. Never had an issue. I don't add a drop of oil between 5000 mile changes. I wanna keep it that way. I know I need to flush radiator and brake lines...change all fluids. Can someone give me a list of what I should do? Belt, hoses, and such. I read in this forum that it has a timing chain instead of a belt. If this is the case, I am not touching that. I'll just hope it lasts 300K. Do I do anything with the transmission (its manual shift)? Its less then 4 years old, so dry rotting isn't as bad an issue as it would be on most cars approaching 200K...however it DOES have a ton of miles on it.
Any suggestions would be highly appreciated.
Thanks,
Brian
Gobuckeyes97 is offline
Old 01-23-2012
Re: 2009 LX with 160K...200K maintenance suggestions?
Gee. I don't see cars get miles racked up fast like that very often here. Does it ever get to cool off?
I would change the trans fluid if it has never been done. 30k might be overkill as you have proven to yourself, but the older cars developed bearing problems rather early sometimes......one could attribute that to lack of fluid service.
How about manual trans fluid every 100k starting now, and let us know if yours blows up?
I really don't see many manual transmissions in these cars, and also haven't seen any problems with them here yet either. Honda MT Fluid
Brake fluid every 3 years. DOT 3.
May as well do coolant too. It is long life coolant, but you have a ton of miles on it. Drain and fill. Honda Type 2, pre-mixed, blue in color. Probably only one gallon.
Serp belt whenever it starts getting a bunch of cracks in it. Turning brown has been normal and is not a good reason to replace it.
Factory hoses have been lasting 15-20 years here in many cases since the early 90's. (not all last that long though.) I'd just check them on a regular basis.
Barring a disastrous overheat situation, I'd expect 10+ years regardless of mileage, but please don't hold me to that.
Aftermarket doesn't last nearly as long as factory.
Wipers?
Whatever breaks, fix it.
HTH
ezone is offline
Old 01-23-2012
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Curiosity is killing me,how do you put so many miles on it?
jordan1794 is offline
Old 06-07-2012
outliersbeau's Avatar
outliersbeau is an unknown quantity at this point
just picked up one of these with 24,000 on it, nice to know it has a good lifetime of roadtrips and long work commutes ahead of her
outliersbeau is offline
mjdiaz89
06-21-2016 09:26 PM
AirJordan613
General 7th Gen
08-02-2015 08:55 PM
breanna_17
07-21-2015 04:01 PM
LorenzoC0395
07-14-2015 08:46 PM
jzhartman
07-09-2015 04:56 PM
Quick Reply: 2009 LX with 160K...200K maintenance suggestions?
