Seafoam
Rep Power: 0 Seafoam
I wanna run Seafoam (carbon cleaner) through my 2006 Civic, but I'm not sure where to put it in. Do I just pour it straight into the throttle body? or is there a PCV line or something that I can use to suck it up into the cylinders?
Re: Seafoam
I use seafoam in my motorcycle and it works really well to help reduce the carbon build up. The easiest way is to just add it to your next fill up of gas. This will allow it to run into the engine and over a tank or two it'll run through and help it out. That's how I've used it and it's worked out well. It's by no means a miracle worker but it helps.
poynterandy
08-09-2011 12:54 PM
dougal813
05-31-2010 05:28 PM
