Front upper strut bar
Rep Power: 0 Front upper strut bar
I have a 03 Civic and I am trying to install the strut bar and I found the break/cluch reservoir is in the way, does this have to be moved or am I doing somthing wrong?
it can be easily relocated if you make sure that you use the right hose so it doesn't crimp.. 'cause that would be bad.. does it seem like it'd fit otherwise? that mostly means you bougth a cheap one.. i had to relocate m y horn when i got mine for the subaru
GH04si
04-15-2015 08:13 PM
