Fuel Injector Cleaner?
Rep Power: 0 Fuel Injector Cleaner?
Does anyone use a fuel injector cleaner additive? The ones your supposed to add every time you change your oil? Is this a good practice or do natural detergents in gasoline already do that? Are there any side effects of adding fuel injector cleaner?
DIY King
Rep Power: 394 I use STP fuel injector cleaner every other time I fill up. It prevents buildup of deposits inside of the fuel injectors and fuel lines. Good stuff. Pretty cheap for what it does. Get the weaker stuff and use it every other day. It should be about $1.50 - $2.00 per bottle.
DIY King
Rep Power: 394 Nah, pg. 162:
<< We reccomend gasolines containing detergent additives that help prevent fuel system and engine deposits. >>
The stuff that I mentioned does just that. It helps to prevent fuel system deposites. [IMG]i/expressions/beer_yum.gif[/IMG]
Rep Power: 0 I used to use injector cleaners on my old Altima. It helps. You just have to remember to run the whole tank with it, otherwise you'll diluted if you fill your tank with new gas before it's empty.
These days I don't nother use injector cleaners. Once in a while I just put in Sunoco 94 instead. It's easier, and in reality it doesn't cost anymore.
fred57
08-01-2015 08:45 AM
Green02civic
07-27-2015 10:48 PM
