Go Back   Honda Civic Forum > GENERAL > General Honda Civic Forum Archive.
Register Forgot Password?
Register Photo Gallery FAQ Members List Search Today's Posts Mark Forums Read Experience GarageVendors TSB & Recalls
Welcome to Honda Civic Forum
LinkBack Thread Tools Search this Thread
Old 10-20-2004   #1 (permalink)
realitycheck's Avatar
realitycheck is an unknown quantity at this point
malfunction indicator light
Alright guys on my way to work this morning and my car was feeling funny like it was missing almost, it was kind of jumping a little bit not too much though. So I look down a little later and my malfunction indicator light is on the yellow one right above the temp gauge that looks like an engine. What do you guys think it is I know its not the gas cap I havent got gas in like 5 days. I do have a high flow cat but i've had it for like a year now and the light has never came on before. What do you guys suggest I do to fix it?
realitycheck is offline
Old 10-20-2004   #2 (permalink)
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Get the code scanned.
4drcivic2k1 is offline
Old 10-20-2004   #3 (permalink)
7thgen Power Maker
dezod's Avatar
Points: 40,876, Level: 100
Points: 40,876, Level: 100 Points: 40,876, Level: 100 Points: 40,876, Level: 100
Level up: 0%, 0 Points needed
Level up: 0% Level up: 0% Level up: 0%
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Images: 57
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Maybe an O2 sensor.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Follow us on Facebook!
W: www.dezodmotorsports.com
P: 716-681-6666
E: sales@dezod.com
dezod is offline
Old 10-20-2004   #4 (permalink)
So if i unplug the negative cable and reset the ecu. If it stays off im good right but if it comes back on check the o2 sensor. Also I have an mil eliminator on the second sensor. Next question is that hurting my engine?
Old 10-20-2004   #5 (permalink)
7thgen Power Maker
dezod's Avatar
Activity: 1.5%
Images: 57
Quote:
The 2nd O2 reads how well the catalization is done. So if you are not running a cat, that could be it. I do not know. Your best bet is to get the code pulled, then assess the problem from there.
__________________
P: 716-681-6666
E: sales@dezod.com
dezod is offline
Old 10-20-2004   #6 (permalink)
master of the culinary martial arts
masarak's Avatar
Points: 10,341, Level: 67
Points: 10,341, Level: 67 Points: 10,341, Level: 67 Points: 10,341, Level: 67
Level up: 73%, 109 Points needed
Level up: 73% Level up: 73% Level up: 73%
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
masarak is a glorious beacon of light masarak is a glorious beacon of light masarak is a glorious beacon of light masarak is a glorious beacon of light masarak is a glorious beacon of light masarak is a glorious beacon of light
If you have an Advanced Auto Parts store, they will read your engine codes for free.
masarak is offline
Old 10-20-2004   #7 (permalink)
How long does that take?
And where do they have to plug into?
and thanks for all the help!
Old 10-20-2004   #8 (permalink)
It usually takes about 5 minutes. The plug is located under the drivers side dash next to the center console.
Old 10-25-2004   #9 (permalink)
Alright guys I got it checked the guy said that the code was saying high voltage to the o2 sensor after that cat. So I bought one and installed it, like a day later the light came back on. What do you guys think it could be? Could it be the mil eliminator or anything else? Please help me!
Old 10-25-2004   #10 (permalink)
Your cat is causing it.
Old 10-25-2004   #11 (permalink)
How is my cat causing the light? I've had the cat for a year and the light just now came on!
Old 10-25-2004   #12 (permalink)
Can anyone please help? Also, does anyone know how to make your own mil eliminator? Anybody?
Old 10-25-2004   #13 (permalink)
Try putting the stock downpipe back on and see if that fixes it. It will eliminate another possible problem.
Old 10-25-2004   #14 (permalink)
Well the only two options is the gas cap and the emissions right! So I know its not the gas cap and I dont want to put that back on, I like the extra hp I have from it.
Can anyone answer my other questions?
Old 10-25-2004   #15 (permalink)
4jacks's Avatar
Points: 12,223, Level: 72
Points: 12,223, Level: 72 Points: 12,223, Level: 72 Points: 12,223, Level: 72
Level up: 44%, 227 Points needed
Level up: 44% Level up: 44% Level up: 44%
Activity: 2.1%
Activity: 2.1% Activity: 2.1% Activity: 2.1%
4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light
Send a message via ICQ to 4jacks Send a message via AIM to 4jacks
If your 2nd O2 sensor is getting High Voltage, it may actually be your MIL.
Did you install the MIL when you installed your high flow Cat?? I would think that just reseting the ECU would be enough to prevent the Malfunction Light from coming on. You will definatly Need a MIL if you Bored out the Cat, or straight piped it. But I don't know, has anyone one here done a High Flow with No MIL ???
My thought would be that the problem is either the MIL, the Sensor, or the wiring, I'm thinking an Aftermarket CAT can not increase the Voltage, and Becuase it's the Voltage it is somewhere in the connection between the Source, the Sensor and the ECU. So check you wiring, your Sensor and your MIL. If it is not one of those then you got me baffled.
Did you get the correct MIL, I don't think they are universal, I'm pretty sure you need one designed for our cars.
Good luck
__________________
Patrick
4jacks
Website
4jacks@gmail.com
4jacks is offline
Old 10-25-2004
CivicForums
Honda Civic
Paid Advertisement
Tags
04 , 2002 , 2007 , air , civic , console , filter , honda , indicator , light , malfunction , mil , sedan , si , wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Removing the cat.? sokka7 Basic Engine Performance 57 03-29-2007 11:17 PM
Air Intake Owners! Ppl With Bad Gas Mileage..cel Wont Turn Off?check This! 2k3HonCivicEX General Honda Civic Forum Archive. 19 12-23-2003 02:42 PM
UPDATE:engine light came on my stock sedan. went to dealer & this is what they said AR Mechanical Problems/Vehicle Issues and Fix-it Forum 18 11-24-2003 12:11 AM
Engine Check Light, PLEASE HELP.... ZSKCivic01 General Honda Civic Forum Archive. 14 01-23-2003 11:52 PM
User Login
Our Partners
used new
Top 10 Threads
Dictionary Of Automotive Terms
60,000 mile Transmission fluid change
Looking for a 7th gen manual for free? (UPDATED!!!)
SOHC VTEC Explained
AC Recharge kit overcharged my system! What now?
ALL of Grey's DIY's...
Oil Changes
Detailed smoked out taillights DIY w/ pictures
Removing door panel from a 2002 civic
Automatic Transmission Flush
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
