Transmission fluid
Old 03-01-2017
adonato95's Avatar
adonato95 is an unknown quantity at this point
Transmission fluid
Do you ever change a tranny fluid or just tap or put additive?
Old 03-01-2017
Re: Transmission fluid
Change automatic trans fluid every 30,000 miles, or more frequently.
What kind of car? What trans?
Old 03-02-2017
adonato95's Avatar
1998 Civic Ex with 193k . Bought it used so just making sure.
Old 03-02-2017
Ok, then.
No machines, no chemicals.
Simple drain and fill of trans fluid. +
If you can change your own oil, this is just as easy.
If you want to get the majority of the fluid changed out, do this multiple times because each drain and fill only exchanges about 2.5 quarts and the trans holds a total of like 6 or 8 quarts.
I'd say drain and fill the trans along with the next few oil changes for convenience.
Make sure you have a funnel that will actually reach the fill hole before you drain the fluid!
Old 03-02-2017
adonato95's Avatar
What do you mean about doing it couple of times?
Old 03-02-2017
Have a read here: http://www.crvownersclub.com/forums/...html#post13701
Old 03-08-2017
adonato95's Avatar
Lucas treatment safe for honda? My mechanic said no treatment for honda tranny.
Old 03-08-2017
Honda does not recommend nor endorse anything but the correct spec fluid.
