What weight oil??
Rep Power: 0 What weight oil??
I have my 2002 civic SOHC. I have always used 05/20 castrol syntec edge but my civic has 207K miles. Its starting to slowly burn oil. Do you guys think I should move up weight to maybe 10/30 or what to you guys recommend??
Rep Power: 788 Re: What weight oil??
anything over 100k i would use 5w30. it will usually fix any slow leaks you have. if you are burning oil, try auto-rx.com treatment and it will greatly reduce it. our old accord went from burning almost a quart a month to now a quart a year. and it runs like a new engine. after the auto rx treatment, try running valvoline maxlife 5w30 for better protection and even less oil burning. if you still have some issues, switch to 10w30 maxlife but only if you live mostly in place where its above freezing most of the year. if you have cold winters, stick with 5w30.
Rep Power: 0 Re: What weight oil??
5w30 will not hurt, but for a newer engine with smaller tolerances, i would stick with the factory oil weight. after a while you will start to see that switching to a thicker weight is better (when you develop small oil leaks and start burning oil after 75k+ miles). thats when a 30 weight really helps out and the engine is more than "broken in" to work with it. and remember that synthetic keeps its weight whereas a conventional will shear down to a lower weight (a 30 weight can become more like 20 weight over time). i would stick with a 5w20 full synthetic from 25k to about 75k, then switch to 5w30. just my opinion. and the reason i say 25k is these new engines have a very long break in time and you want to make sure and stick with conventional from 0-25k if you want the engine to last later on. 25k is a bit extreme and you are prolly fine waiting until 10k, but better safe than sorry.
the most important thing to remember is pick a weight and a brand and stick with it. mixing too many oils every time you change it can reduce its effectiveness.
brags
46
01-07-2016 09:39 PM
emich
12-11-2015 12:20 PM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
