Heater not working
Old 10-28-2009
CivicRen's Avatar
CivicRen is an unknown quantity at this point
Heater not working
Hey there. I have a 2003 Honda Civic LX, and there is no hot air coming out when dials are turned to full heat and the fan is turend to max. The same thing happens when I turn on the AC. All lights AC and heating lights still come on. Any suggestions? Thanks alot, much appreciated.
Old 10-28-2009
Re: Heater not working
how is your coolant level? you may have some air bubbles, or the heater core might be clogged. does the car overheat?
Old 10-28-2009
lowlife9's Avatar
does the heat work when your driving and then stop when the car is stopped ???
Old 10-29-2009
CivicRen's Avatar
I haven't checked the coolant level yet. The fuses are fine, I feel a little bit of heat coming out of the vents but there isn't any circulation going on. Could the fan motor be busted? My car hasn't overheated yet..
Old 10-29-2009
do you have air coming out (warm or cold) when the fan is on max?
Old 10-29-2009
CivicRen's Avatar
When the fan is on max, I have absolutely no cold or warm air coming out of the vents. When I turn on the accessory power, I can hear (what i believe to be) the fan motor turning on then it stops. I do hear clicking sounds coming from the vents when I turn the temperature **** from cold to hot.
Old 10-29-2009
then its either a bad blower motor or the blower motor resistor. its the big fan thing under the glove box.
Old 10-29-2009
CraigW's Avatar
01-05 Civics use a "transistor" instead of a blower resistor.
If the fan is running you should be able to hear it.
Old 10-29-2009
CivicRen's Avatar
That makes alot of sense. Thanks for suggestions!
Old 10-18-2011
SSDiamond05's Avatar
SSDiamond05 is an unknown quantity at this point
I would say check the cabin air filters, they plug up and then no air can get through, they are behind the glove box.
ezone
24
10-30-2017 11:27 AM
R3KogHyZe
21
02-03-2016 09:23 PM
werdnahall
05-17-2015 11:37 AM
ORskier
05-03-2015 12:54 PM
CascadiaBlue
04-18-2015 09:13 AM
Quick Reply: Heater not working
