don't use premium gas
Old 04-08-2007
  #241
RHCP0801's Avatar
Re: don't use premium gas
i wouldnt do it, the gases(fumes) need some space in the gas tank too
Old 04-08-2007
  #242
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
If you fill the car past when it clicks off you will fill up the vapor canister with liquid gasoline and over time it will damage it. Im supprised you havent gotten a CEL yet if you go till its almost gonna overflow.
Old 04-08-2007
  #243
Alpha 5's Avatar
NO CEL at all. I fill it up till it won't hold another ounce. I have done this every fill up. About 1 every two weeks or so for the last 3 years. No harm yet, that I know of.
Old 04-09-2007
  #244
Johnold's Avatar
Johnold is an unknown quantity at this point
I have NEVER heard this ^ before!
Old 04-09-2007
  #245
dopes6070's Avatar
happened to my GF's car and they had to replace the canister for it to pass smog. The code was p1457? I believe
Old 04-10-2007
  #246
Alpha 5's Avatar
So other than the possible evap canister harm. Is there anything else I should worry about? I live in Oklahoma and we do not have to pass any type of emisions tests.
Old 04-10-2007
  #247
fightax's Avatar
fightax is an unknown quantity at this point
totally agree with sujak..my girlfriend does the same ****..lol i tell her the same thing..*smack.. lol jk xP
Old 04-10-2007
  #248
Johnold's Avatar
I go till it clicks than round off to the nearest dollar, like every normal person
Sujak - thats exactly what i do. or go to the nearest half dollar amount. so if i pump $16.24 cents, i just get it to $16.50 or 75 cents. i never put anymore than 1 extra dollar worth in my car. this is kinda scary to me finding this out in the first place cause i just bought an 07 Si and i've filled up the tank 3 times so far and i've done this "overfill" all 3 times so far. i'm hoping that i'm not doing much to hurt her
Old 04-10-2007
  #249
dopes6070's Avatar
going a little bit more wont hurt it... but going till it almost overflows can...
Old 04-30-2007
  #250
Got Boost?'s Avatar
Got Boost? is an unknown quantity at this point
My step-father is a mechanic and he had some input so he told me their is no gain to going high octane but he said a mechanics trick is to run higher octane through your engine for about a week or two for like a cleaning because believe it or not it is cleaner but the purpose of higher octane is a total different issue like for a turbo etc.
Old 04-30-2007
  #251
sl33pyriceboi's Avatar
^um........
Old 04-30-2007
  #252
its true, higher octane gas contains more detergents in the top teir program. but it is still not enough to matter, and certainly not enough to justify using high octane gas in a low compression motor. its much better to use something like lubecontrol.com in every tank. that actually works.
Old 04-30-2007
  #253
ronaldo9's Avatar
I'm probably the oddball guy here but I've experimented with all grades and 89seems to run the smoothest with my stage 2 cam. 87 runs way rich and I get no gas mileage like 280 to a tank on city driving. With 89 and 93 it bumps up to 320+. All highway I've hit 370-390 on a tank. Not sure which one makes more power I'll have to do some dyno runs with the different grades to really tell. 93 I ran leaner for some reason but it drove no better than 89 so I figured 93 was a waste even if I have no cat. Just thought I'd share my experience.
Old 04-30-2007
  #254
i believe one time is enough to do considerable damage that your car wont be the same again.
Old 04-30-2007
  #255
who? lol i believe the big guys are using hi octane unleaded.
Old 04-30-2007
  #256
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
^^^Yep 94 octane
Old 04-30-2007
  #257
New Member
Conspiracy Of 1's Avatar
Conspiracy Of 1 is an unknown quantity at this point
every so often i add high octane to my fuel, is this bad for it then.
Old 04-30-2007
  #258
ronaldo9's Avatar
No its not bad... the consensus through these 18 pages are that its a waste for our fairly low compression civics that run perfectly fine on 87. Gearbox said it all... use some fp60 or other lubecontrol products.
Old 04-30-2007
  #259
EMK20a2's Avatar
If you are really concered about keeping the fuel system clean then I would say use Shell gas, they all have adatives to help do this. The only reason I don't use shell is they don't have 94 octane, like Sunoco
Old 04-30-2007
  #260
red_civic_boi's Avatar
red_civic_boi is an unknown quantity at this point
i dont care wat people sayin but im using 87 till i get the turbo then i'll use 93 lol...
CarStuff
12-06-2020 12:52 PM
mattdoc
03-14-2017 12:10 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
bsmiley
04-27-2015 01:27 PM
tylerginevan
04-27-2015 12:29 PM
Quick Reply: don't use premium gas
