DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Senior Member
Rep Power: 0 DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
www.home.earthlink.net/~profuse007/id3.html
finally got around to do this write up..... just got camera (some pic blur)
have fun
have fun
Rep Power: 288 Its not easy - this is a job for someone who has done something like this in the past....
If you aren't comfortable without having your car for a day or 2, take it to a professional. It took me 2 days to install my clifford....
Senior Member
Rep Power: 0 I broke it down into ttwo parts: 1. install the alarm/RS/keyless unit
2. install the 555I, antitheft bypass
the tutorial is planned out. read all the diagram, i marked all the wires you need and not need and maybe needed for installation. if you have ?, just ask.
whats good about this tutorial is that you can pretty much get any DEI products. theres like 10 diff type of units made by DEI that have an exact diagram.
Senior Member
Rep Power: 0 it shouldnt be complicated, ive tested every wires and ensure the right connection. there are pics of the locations on where to get those wires in ur civic.
all y'all have to do is make connections.
Originally Posted by nunzio42
wow, looks complicated, but thanks for the diy......been looking for one for a while
Senior Member
Rep Power: 0 Clutch Bypass
plz do not ask me about tempoarily bypassing clutch when RS. the unit is made for automatic EFI.
i nor this site dont think either of us should encourage this kind of hazard...... just email if youre just so curious.
NEXT tutorial: ill try to write up a compustar 2wss-as for MTranny civics. this unit is safe for MT's.
Senior Member
Rep Power: 0 the installation time is appx ~4hrs for average isntallers out there.
the installation time is appx ~1day for DIY (better start early in the morning)
what clifford model did you used?
The hardest part is splicing in all of the wires, especially the ignition kill, since they are so large. Other than that, routing the wires is the second hardest thing.
Senior Member
Rep Power: 0 ill install the exact unit on a buddy's 01 prelude tomorrow.
some of the wire is kinda hard to read. the ignition is the easiest place to splice through, all the honda and acura have worked on the past are very similar in guage size and insulation size.
you prolly didint open the steering wheel shroud like i did to access to top end of the harness.
I have an intelliguard 850....
Senior Member
Rep Power: 0 its all about find wires and connecting them together
here are some of the things you need to remember. these task takes practice and self torture when you first beginnin to install car alrm/RS this honda is quite simple compare to the others. as long as you read it several times and ask what you need to ask, anyone can DIY this.
THE FIRST LETTER!
Rep Power: 0 Had one installed on the wifes Highlander. They came to my job and installed it in the parking lot. It took about 3-4 hrs. Best investment ever! Now my wife and kid won't freeze anymore waiting for the car to warm up.
The damn thing can start the car 1000 ft. away. Good when you are at the mall. By the way you still have to insert the key in the ignition and unlock the car with the remote (car stays looked while warming up). If you forget you started the car it will shut down by itself in15 to 20 min. It will also shut down when you press on the brake if the key is not in the ignition in case some a$$hole tries to jack you $hit.
All and all pretty good stuff I hope you enjoy yours.
Re: DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
Any way we could revive that DIY link?
I need assistance in installing a Viper alarm on 01 Civic LX
Specifically how to wire up Unlock/Lock features of alarm
Thank you
Thank you
Rep Power: 0 Re: DIY: DEI (viper/clifford..) RStart/keyless/alarm INSTALL
It's probably too late, but here's a shadow copy without pictures...
https://web.archive.org/web/20130415...se007/id3.html
Fuhh. I never got around to seeing the original link but here's a diff DIY Viper install (w/ pics) that I just found half an hour ago. http://civic-eg.com/causeforalarm/em_civic/index.php
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
17
07-23-2015 11:48 PM
EM_WON
07-22-2015 06:49 PM
