2004 civic Mechanic Special
For Sale2004 Honda Civic
Price
$800• OBO
- Location Kingman, AZ, 86409, USA
- Condition Used
- VIN 1HGEM22354L075666
- Trim VP
- Mileage 237,179
- Engine 4 cyl
- Drive Type 2WD
- Transmission Automatic
- Vehicle Type Coupe
- Exterior Color White
Description:
Original owner all maint. and repair records last 20 years.Has a broken timing belt. a few minor dings left front fender. Tan cloth interior new brakes.The majority milage driven long distance. for work travel. Car is in original condition and no rust
Re: 2004 civic Mechanic Special
Just out of curiosity (for any potential buyer's sake), did the timing belt break while the engine was running? Could be the difference between a 4 hour job TB job and and an engine overhaul. Super clean though, especially considering almost 240k on the clock. GLWS
Timing belt broke while idling in parking lot. The motor backfired once and quit. Tried to re-start but failed. Towed home,removed cover and confirmed belt failure.Then re-timed engine (crank to cam) . Re installed new timing belt and tried to start . Motor turns over but won't fire. I was informed that some valves were likely bent due to interference.So at a minimum the head needs to be repaired or replaced . The car is in very decent condition otherwise and has a clean AZ title. Selling as a fixer or salvage.
Thanks for the update. I'd 100% put all my money on valves being bent and it won't fire due to no compression. Not a terribly hard fix for someone that has mechanical know-how. For the curious, you'd have to pull the head, inspect tops of the pistons (due to interference engine design -- honestly should be fine), disassemble head, replace valves, reuse basically everything else that's not a gasket or seal (if you buy a head gasket kit, all required top end seals are included), slap 'er back together, replace fluids. My 2002 had a timing belt undergo a similar treatment upon hard acceleration at 3000RPM and bent all 16 valves. Pistons were 100% fine.
Good luck with the sale!
