2009 Civic Hybrid Shudder
Old Feb 2, 2018
esemeryuk's Avatar
esemeryuk is an unknown quantity at this point
My 2008 honda civic hybrid 1.3L shudders when i accelerate. I heard that this could be do to engine mounts, so i swapped all three of them out. The issue still persists. Does anyone know any other possible reasons this could be happening?
Old Feb 2, 2018
Re: 2009 Civic Hybrid Shudder
Should have checked if the mounts were actually bad before swapping them out. Could be that there's something wrong internally in the trans. Hows the fluid look? Level? Serviced regularly?
Old Feb 2, 2018
Trans fluid services......critical......
Use of incorrect fluid can cause some really weird things to happen....and there's a whole bunch of fluids that are flat wrong for that trans.
This is the correct Honda fluid:
Any way you can video the shudder so we can feel it too?
Did the issue start all of a sudden, or was it a slow progression?
Old Feb 3, 2018
esemeryuk's Avatar
I don't know if it's been serviced regularly. The car has just over 30k miles on it at the moment and i got it at around 25k miles. The shudder was only slight when i first got it but recently it's begun to worry me as it's much more noticeable now. However I will check on the trans fluid and possibly swap it out
Old Dec 25, 2019
Braun2021's Avatar
Braun2021 is an unknown quantity at this point
Had a shudder on my Civic Hybrid 2008 at 126,000 miles and the engine light fluttered, then went on later in the day. It turned out some coils failed on the back of the engine (rear side). It looks like some service people just replaced the front spark plugs and left the back ones to fail and put stress on the coils. I replaced 3 coils and plugs and it runs fine now.
mgrantaz
General
May 2, 2022 05:40 PM
CaptainH
Dec 27, 2015 02:02 PM
itsfighter
Oct 31, 2011 06:11 PM
yamahar6
Nov 23, 2010 07:39 PM
texasvortex
Jun 16, 2005 11:55 AM
