Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Leaking Clutch Fluid
1995 Civic EX coupe, B20 swap, Manual (LS) transmission.
Found a few drops on driveway today and couldn't identify the substance. After returning home for a thirty mile drive I had trouble getting into reverse gear my car into parking space and clutch pedal wouldn't return to resting position. Turn off engine then easily shifted to neutral. Clutch pedal returned to resting position. I checked the clutch cylinder and fluid is visible but below "low" fill line. Being that it's dark out and my suspension is low I didn't bother looking for the source but my guess is the slave cylinder is leaking based on locations of the drips. No fluid seen on or near clutch master cylinder.
Should I not use the car until I can tow it to where I can work on it?
If it is the slave cylinder..any tips or recommendation for repair?
Transmission is from a '96-01 Acura integra LS... Is the slave cylinder the same dimesions as a D-series?
Re: Leaking Clutch Fluid
Squeeze the boot on the slave or peel it back a bit on the large end, see if it's holding a bunch of fluid. If that's holding fluid, that means the slave has been leaking.....and if the boot retains all of that leakage it can push the piston inward and make the pedal feel "lower than usual"
If needed, order one for the car that trans came out of.
Random goggle image with the correct boot already circled:
Okay Thanks. I'll take a look at it tomorrow.
If this one is correct OEM part it looks to be interchangeable with 5th & 6th gens Civics too: http://www.new-part.com/product/acur...yABEgIWUPD_BwE
I'll check with me local dealer..their parts prices seem to be competitive with Honda genuine sites.
11. There are a bunch of different ideas of how to bleed the clutch but this is what has always worked for me. a. Fill the clutch master cylinder reservoir. b. Have my helper pump the pedal with the bleeder open and the cap off the clutch master cylinder (since it was completely empty) c. Once it started coming out of the slave bleeder I tightened the valve. d. Top off fluid in master cylinder and secure the cap onto it e. Have helper pump the clutch 4 times then hold it down. f. Quickly open the valve with the clear hose still on it. (watch for bubble etc) then CLOSE the valve. g. Have helper pull the pedal back up (it will be stuck to the floor) and repeat steps "e" and "f" but only a maximum of 3 times before adding more brake fluid to the master cylinder. This way you won't run out of fluid in their and accidentally suck air into it, causing you to have to do this process all over again h. When there are no more bubbles coming out of the slave cylinder your clutch lines will be sufficiently bled, tighten up the valve, make sure the clutch pedal is firm and take a ride.
Pulled the slave cylinder boot and a few ounces of brake fluid was in it.
Looks to me like it's okay to drivetoday to pickup a part and drive to where I need to replace it. I'll most likley gravity feed bleed it.
As much as I know better not to I'm going the Autocloned route for AM part. How long do you think a $13 dollar clave cylinder will last?..lol. Wait, it's a "lifetime" part and that means I can return it a limited amount of two times. That's an odd definition of "lifetime".
It probably works right again now that the excess fluid has been burped out of the boot?
My truck did this shortly after I got it..........I snipped a slit in the boot to let the excess seep out to the ground, and now I just top off the master reservoir once a year.......it's been this way for the last 20+ years.
You better be ready to bleed every other possible way besides that---- if it doesn't work as planned.
Lifetime part: Good for the life of the part
For the price you can probably afford to pay for the 3rd one in a few years. Will you even have the same car by then?
I had that exact thought as well before purchasing the part. I haven't installed it yet so I will drive around a few days and check fluid each day to see if lowers. I live in condo so I have to repair any type of leak as soon as possible.
It started leaking after I let Lil' Dong drive it recently. He was going on about his rev-matching heel-toe clutch technique. The little turd probably caused the issue..lol
I asked an employee at Azone about that today and he said their's are truly lifetime. O'Reilly's, Advanced and a few others have full lifetime on some parts and limited (lifetime) returns on others. I purchase a CV axle a few years ago at Advanced and they said two returns only but is labeled as lifetime.
Installed new slave cylinder and seems to be working well. ETCG has good tips for install and another youtuber has a good video on gravity feed. I used gravity feed then finished with pedal-pump bleed with my old-timey helper a.k.a. Mom.
Clutch pedal seems a bit easier to shift. There's some dark sediments in clutch master but I couldn't see them when bleeding air from fluid in the slave cylinder.
