srs connectors under seat...cut
Old Oct 8, 2017
310civicEX's Avatar
310civicEX is an unknown quantity at this point
does anyone know why somebody would cut driver and passenger, connectors connected to the seat belt buckle...not the round yellow one.. the regular box kind... srs light is on..
Old Oct 8, 2017
Re: srs connectors under seat...cut
Fix the wires....then you can find out (if) the buckles are bad causing codes.
Old Oct 8, 2017
Man, reading all your threads, previous owner did a number on that car. Jeebus
Old Oct 9, 2017
310civicEX's Avatar
hahaha yep.. engine and body are good though.. needs clutch and master/slave cylinders.. the rest shoudnt be a problem..
Old Oct 9, 2017
Is this the car that came from your boss or was that someone elses thread?
Did you get the car from someone who hates your guts? LOL
Old Oct 9, 2017
5.0Thunder's Avatar
5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough5.0Thunder is a jewel in the rough
IS this the no-oxygen sensor car?
Old Oct 9, 2017
310civicEX's Avatar
lol yep.. it will be soon tho..
Old Oct 9, 2017
310civicEX's Avatar
there are 3 connectors under the seat... the green wires with yellow connector that is connected to the belt bucke is cut.. trying to find out what it goes to.
Old Oct 9, 2017
310civicEX's Avatar
DRIVER SIDE
PASSANGER SIDE
Old Oct 9, 2017
That's the harness that comes up from the floor under each seat?
Old Oct 9, 2017
310civicEX's Avatar
yep.... both are going to the belt buckle.... i got 2 connectors on each buckle
Old Oct 10, 2017
The buckles flat 3 wire connector is for the SPDT microswitch inside the buckle.
A screaming yellow 2 wire connector is for a pyrotechnic charge for the SRS system, if it goes to the buckle area then that buckle can be fired by the SRS system to tighten the seat belt. (tensioner) Colors will be some combo of grn/blk, grn/yel/ grn/red, and grn
Seat belts can also have their own tensioner systems too.
(There is also an airbag in the side of both front seatbacks (side airbag) on most of the cars (upper seat cover will have a tag stating so), it also uses a screaming yellow connector...and the passengers seat has the OPDS system which adds something like 4 more wires.)
This style buckle has it in the long tube:
Side by side, SRS tensioning vs. plain:
You could enter your VIN in an online parts catalog, figure out what parts of the system it was supposed to be equipped with....
Maybe the floor harness was changed out and it had too many wires?
Seats changed out and there was too many wires?
Nah....that's too logical for what all has been hacked on that car.
