225/45/16?
Old Mar 22, 2005
CarRamrod's Avatar
CarRamrod is an unknown quantity at this point
225/45/16?
Hey im thinking of getting some 225/45/16 AVS ES100 tires for my sedan, do you think they will be to wide. any input would be appriciated. thks.
Old Mar 23, 2005
Black03civic's Avatar
i too was thinking of getting 225/45/17 for myself and want to know also.
Old Mar 23, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
I had 225/50/16 Goodyear eagle f1 gsd3 tires on my ssr comps ... the backs rubbed if you don't have a camber kit and the fronts will tear up your wheel well covers when making u turns.
Old Mar 23, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Whats the offset on the wheel they're going onto? I've seen 225s fit, I've seen them not fit as well. With a low offset, you can do it. Tire height with a 225/45/16 doesn't play into this as its shorter than stock, but the width will make a major difference.
Old Mar 23, 2005
CarRamrod's Avatar
My rims have a +40 off set, i haven't lowered it yet, probably going to get Eibach prokits.
Old Mar 23, 2005
Vantage's Avatar
Vantage should not be trusted
my friend fit 225/45/17 falken's with 38offset, on a stock height 2002 COupe
Old Mar 24, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
Use camber as your freind here....your going to want to make sure those tires dont rub at all. You should be fine but those tires are alot smaller then stock so your going to have to slam your car to get no wheel gap.
Old Mar 24, 2005
ironchef's Avatar
There is no substitute
ironchef is an unknown quantity at this point
Other than the width issue, the 225/45r16 are close enough in overall diameter, but I think 225/45r17 might be too big. The overall diameter is increased by quite a bit, which combined with the increased width might not work too well.
Old Mar 25, 2005
thanks for the information, after doing more reseach i think your corect on this matter
Boilermaker1
May 27, 2016 09:15 AM
X3R0CO07
May 1, 2014 07:28 PM
dru106
Aug 8, 2007 02:36 PM
01vic
Oct 10, 2006 12:48 PM
chad_everson
Jun 25, 2004 07:19 PM
