CF hood won't close
Old Jun 22, 2003
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
Exclamation CF hood won't close
I just bought a CF hood yesterday and tried to install it and it wouldn't go all the way down. I did a search and someone said something about the hood levelers...i think they are the two black things near the headlight. Me and my friend tried adjusting those and it would not fit. It closes but something is in the way. When i shined a flashlight into it...it looked as if the silver thing that hooks on to the CF hood is hitting against the hood. Not sure how to fix this but any suggestions would help.
Old Jun 23, 2003
djmota's Avatar
if the silver thing you are talking about is the hook. then try bending or grinding just the pointy top over to clear.
Old Jun 23, 2003
vistec's Avatar
vistec is an unknown quantity at this point
loosen the 3 screws that hold the latch to the car...move the latch lower...then it should close....
Old Jun 23, 2003
bboysushi's Avatar
bboysushi is an unknown quantity at this point
whoops seems like it wont fit your car huh?
i will buy it from you now! LoL jk
hope it works out for you
Bboysushi
Old Jun 23, 2003
v8eaterokv6's Avatar
i have a new home do u
i had the same problem i just trimmed the rubber stops down a little and it fits. i have to kinda push and drop at the same time for the hood to latch but when it is latched it is tight. good luck
Old Jun 23, 2003
cdmx's Avatar
where did you buy it, what kind?
Old Jun 24, 2003
Booohahaha's Avatar
BAD MON
ouch!!... i took mine to the shop and they put it on for me hehe..
Old Jun 24, 2003
for how much boo?
Old Jun 24, 2003
Booohahaha's Avatar
BAD MON
it only cost me 60 bucks CDN. and they just took one of the latches that hold the hood and modified it. and it fit's fine...
i got some taiwanese replica but hell... its light as hell and fitment is perfect!!
Old Jun 24, 2003
Samari's Avatar
took it to a shop to put on a hood that takes 5 mins to put on by yourself. wow.
Old Jun 24, 2003
viciousvolpe's Avatar
viciousvolpe is an unknown quantity at this point
2 words.....hood pins
Old Jun 24, 2003
Nelly's Avatar
Nelly is an unknown quantity at this point
i had the exact same problem when i installed mines...cf hoods will never ever fit like a glove...but theres a trick...make sure its aligned rite by loosening the bolts...adjsut the hood..than tigghten em..and for the cf hood...u hafta slam it...slam it alot more than u would normally dow id the sotck hood..give it a try..it worked for me
Old Jun 24, 2003
Weaponx12o's Avatar
hey, i know how it feels, i had that hood before walter haha. just take out all the rubber stoppers on the frame of the car. close the hood (not all the way) lift up the lever and the hood should come down a bit, then press down to fully close it. once you get the hang of it. put the two rear rubber stoppers back on, you'll need those to reduce hood vibration. if you cant close it with the rubber stoppers, try the other 2. if it still wont close, you might have to get hood pins
btw, my new cf hood fits perfectly! no gaps or anything. its made by bodykits nw
Old Jun 26, 2003
J30A1's Avatar
J30A1 is an unknown quantity at this point
thanks for help..but i got his hood to close already.
Civic15
18
Sep 19, 2017 07:48 PM
orangeju1ce
Jul 14, 2015 08:32 PM
beeemerdude
Jul 10, 2015 09:22 PM
Trennytrent
Jul 10, 2015 09:01 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
