Nuespeed strut
Old Jun 15, 2003
Da1lyDr1ver's Avatar
Nuespeed strut
i searched the forums and am kinda confused about the installation of the nuespeed front strut bar. do i have to relocate my brake fluid or power steering containers under the hood, or is the installation just straight bolt on. will the strut bar fit without relocation of the powersteering or brake fluid containers? oh, and do i need to jack up my car to install the bar? thanks for you help
Old Jun 15, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
as far as i know, the only thing you have to worry about is the clutch master cylinder but that will bend around it
Old Jun 15, 2003
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
direct bolt on !
Old Jun 15, 2003
MIT's Avatar
MIT
MIT is an unknown quantity at this point
if you drive 2001 model, u need to relocate brake fluid, if 2002 model, just driect bolt on, but some cars its required you to jack up the driver side a bit to align to fit. easy job~
if not sure, neuspeed come with a instruction manual. so that tell ya everything u needed to know. peac
Old Jun 15, 2003
xgodxicex's Avatar
xgodxicex is an unknown quantity at this point
are you sure? because i thought bending around the clutch master cylinder would cause a imbalance with the torque column steering fluid injection?
Old Jun 16, 2003
Voiceofid's Avatar
End Bringer
i have a 01 auto, and the bar went right in without moving anything
Old Jun 16, 2003
R3DL1N3's Avatar
i had to bend the clutch fluid thing back a little but no biggy.
Old Jun 16, 2003
xgodxicex's Avatar
did u really?...i thought u only had to do that on the dc sports (well move it down) ... hmph...i get my strut bar in on wednesday (neuspeed) ... should fit on no problem
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Wariogamer
Sep 29, 2015 09:49 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
