New Rotors for my 2003 :o
Old Jun 13, 2003
Screaming Fist's Avatar
Screaming Fist is an unknown quantity at this point
Alrighty, my stock rotors warped, not covered under warranty so I'm going to buy a pair of rotors for my 2003 EX w/ ABS (if that matters) Problem is, I'm dumb and don't know what I'm doing I'm not really looking for flash in the rotors, I just want a set that isn't going to warp as easily as the stock ones did.
Any ideas?
Old Jun 13, 2003
RedDragon333's Avatar
brembro cross drilled rotors are good unless you like spending the cash i went with bigger rotors and custom fit the 00 CIvic SI calipers for more coverage. but it wasnt cheape. if your looking just to get better rotors brembros are very nice. Not too pricey either
Old Jun 13, 2003
how did you wrap your rotors on a 03? I have an 01 and have never even gotten close. Is resurfacing the rotor out of the question>
Old Jun 14, 2003
jongreenway's Avatar
jongreenway is an unknown quantity at this point
I had to get something replaced in my brakes, I think it was the front rotors. I was "hot rodding" my civic too much, and I would get a grinding noise when I used the brakes (like as if the brake pads were totally worn out). Turns out because of how I drove, I melted something in the brakes, and left a solid cover over the brake pad and that wrecked the rotor and stuff. Warranty covered it
Old Jun 14, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
X drilled brakes will make it worse... now there's holes in the rotor. X drilled rotors have a tendency to fracture, and Brembo even says they're not for race purposes...
Go for the Brembo SLOTTED rotors. They're about $160, and make sure you get real ones, not 3rd party machined blanks.
Old Jun 14, 2003
Zzyzx's Avatar
Autocross Junky
if all you are looking for is a better rotor, you don't need Drilled or slotted rotors, just get a set of brembo blanks. They will do fine for your needs.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
JetsterDajet
52
May 8, 2016 12:11 AM
First Car
Sep 8, 2015 08:54 PM
MamaBear2015
Sep 7, 2015 06:00 PM
rainman15
Sep 6, 2015 11:10 AM
