taking out spare
Old Jun 13, 2003
R3DL1N3's Avatar
taking out spare
if i have 17" tires would the spare really be worth having? id like to take it out for weight purposes.
Old Jun 13, 2003
Weaponx12o's Avatar
yes, if your tires blow, you wouldnt want to be driving around on bad tires. it'll damage the rim
Old Jun 13, 2003
R3DL1N3's Avatar
but if i was riding 17"s, with one 15" wouldnt the 15 just hang off the ground?
Old Jun 13, 2003
Weaponx12o's Avatar
no, although your car might be lop-sided, your suspension will adjust and all 4 wheels will touch the ground
Old Jun 13, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
17" rims come with low profile tires, but the overall diameter of the wheel is still pretty much the same. 15" rims has 4" thick tires, 17" has 2" tires (just an example), total diameter still 19". ^_^ of coures that's not exact, and you're car will be lopsided so the steering will be quite off to one side.
Old Jun 13, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
Your suspension will do its best to adjust, even with a little space-saver donut spare (Unfortunately I know from experience -- I have had 2 rear tires go out on this Civic)
It's not worth killing your nice new rims or being stranded in the middle of nowhere just to save the weight of your spare tire. You can take it out after you get to the dragstrip
Old Jun 13, 2003
RedDragon333's Avatar
I plan on buying a spare 17in VX8 and fitting it in the spare spot just in case i get a flat tire that way im in and out in a few mins and still rolling. Since i have AEM brakes up front i cant really use the spare, it requires a least a 16
Old Jun 13, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Simple solution... Take a rim off the back, put the donut on, put the rim you just removed from the rear and put it on the front. Done... I just saved you $275 for an extra rim and tire.
Anyways... As long as the outside diameter of the 17" wheels + tires remains the same (i.e., you used the tire calculator and picked the right size), then it's no different than putting the spare on with stock wheels. It will look just as lopsided. The problem is if the car is dropped... cuz usually the spare drops the corner its on another 1"... so you might want to watch for that. If you're worried, get a real 15" steelie and a full size tire.... thats much cheaper than a new rim, and you'll rarely have to use it. I always leave the tire in, just in case, then I take it out at the track... where weight makes a difference.
Adam925
Nov 19, 2019 10:56 AM
Supramk3
Jun 11, 2015 11:13 AM
Supramk3
May 11, 2015 07:55 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
0100010
Dec 1, 2001 03:27 PM
