Aero Sides
i have an 01 coupe and i purchased the aero sides, but i cant get them to fit. they are off 1/2 inch. has anyone had this problem? for those w/an 01 and installed the aero sides how did u get them to fit?
thanks for all your help
thanks for all your help It should fit for 01-03 Civics. What do you mean it's off 1/2 inch? Is it 1/2 high or low? Or is it 1/2 inch more towards the front or back of the car?
I have an 03 with the Aero sides, but the year shouldn't matter.
If you're talking about the horizontal alignment, then to my knowledge it's supposed to be off, but not by much (1/2" sounds about right). But if you're talking about vertical alignment, then just take off the metal 3M tape clips and move them up a little more.
i guess its kinda hard to explain. its 1/2 inch off horizontally. meaning that its doesnt wrap around - doesnt fit side to side. its almost like you have to stretch it out, but it'll break. is it alittle more understanding? and you followed the instructions? i've done numerous searches and none about this problem that i am having. sorry to bother you
Hope this helps you, just PM me if you need more info/help.
NorrinRadd, I had the same problem about putting the clips too high causing a gap between the kit and the door. It's about a 1/4" gap. I just left it. I was going to move it down further, but it was very hard to take off. Leaving the small gap wouldn't cause a problem, right? I did the other side right though.
Do you think I'll still be able to fix that problem? Or should I just leave it? I figure if I go ahead and fix it, I'd have to buy new metal clips (for the driver side only) so it'll stick better.
No problem... Just an FYI though, no matter how small the gap or how flush, water and dirt will always get through over time. My old OEM sides had no gaps whatsoever, but the 3M tape was already eating away after only a year. Wasn't too bad though, since a lot of the tape was still left and still very strong. Like I said a major b!@cth to take off...
muttleytm
Jul 11, 2015 06:00 PM
ballmich
Jul 9, 2015 11:59 AM
