what to torque the header bolts to?
Old Jun 5, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
Where can i find or can anyone tell me what all the bolts on the header need to be torqued too? Can i just use a regular wrench i tighten them good or do i absolutely need a torque wrench and exact numbers?
Old Jun 5, 2003
robbclark1's Avatar
Retired suspension supermod.
Tighten them as much you can get them without breaking anything. they really don't need to be torqued.
Old Jun 5, 2003
thanks alot man i appreciate it
Old Jun 5, 2003
thanks alot man i appreciate it, also does anyone know what size gasket i need to get for the kamikaze header where it connects to the rest of the exhaust piping?
Old Jun 5, 2003
djmota's Avatar
the proper torque is 23 ft lbs just FYI
Old Jun 5, 2003
CapYoda's Avatar
Escaped Convict
actually... almost all the bolts have torque specs.. its so you dont strip the threading..
ESPECIALLY the manifold bolts.. cuz the top two are easy to strip.
EX:
the 2 bolts on top are 23 lbs.ft or 31 n.m
the 3 nuts below are 23 lbs.ft
the heatshield bolt in the middle is 17 lbs.ft or 24 N.m
DX/LX/HX:
the 2 bolts on the top are 23 lbs.ft
3 nuts on the bottom are 23 lbs. ft
the TWO cover bolts for the heatshield are 7.2lbs or 9.8 N.m
the two bolts on the bottom that holds the header to er... hmm something. lol. (not the two bolts that hold the header/cat to the downpipe) are: 33 lbs.ft or 44n.m
for the bolts with the springs on them that connects the headers on the downpipe both ex and the rest:
16 lbf.ft or 22 n.m tighten the bolts in steps, alternating side to side... this will ensure that the header will be fitten on correctly.. without one side being too tight and exhaust leaking...
I think thats all for the header.
oh wait. oxygen sensor 33 lbf.ft or 44 n.m
Old Jun 5, 2003
thanks for the info, so should i go borrow a torque wrench from someone or will i be ok without?
Old Jun 6, 2003
CapYoda's Avatar
Escaped Convict
eh if u want.
just dont over tighten.
UltraHDGames
Jun 8, 2016 05:16 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
anubis62
Sep 27, 2015 12:56 AM
