Your answer may be here! TSB / Honda Complaint Address / Etc...
Old Jun 4, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Enjoy reading! Took me a lot of time to put this one together...
NHTSA Recall / Complaint Center / TSB
AllData.com TSB Center (Easier)
There 210+ TSBs for the 7th Gen Civic.
Just print it out and take it to the dealer. All TSB's are usually replaced at no cost.
Here are some TSB:
Squeaky Clutch Pedal Fix
Diagnosis and fix for rear main oil seal leak
Fix for window rattle
Front suspension noise
Driver's seat rocks back and forth
Inaccurate fuel gauge
Cracked fog light
Engine makes rattling noise
Noisy or stiff steering
Windshield cracking in corners
Rear seat lock hard to turn
(Thank you PESTLNC)
Rattling noise when driving in the rain / buzz sound from under car during rainy days
(Thank you 01civicboi)
2nd and 5th gear popping into neutral
(Thank you flotsamm)
Idle or Stalling in manuals
(Thank you Pharoh)
flotsamm's screenshot of some TSB's
Look at the reply below for instructions on how to download them
Honda/Acura Owner's Link
(Download the Civic manual here!)
Want to complaint directly to Honda?
American Honda Motor Co., Inc.
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Other quick FAQ's
1. My "Main't Req" (Maintenance Required) light blinks / is constantly on?
Push the trip odometer reset, turn the key until the dash lights all come on (don't start it)
Hold it until the Maint Reqd. Light shuts off.
Turn the key off and take your finger off the button.
(Thank you Boilermaker1)
2. "Engine check light" is on...
a. Reset ECU (Disconnected BLACK terminal of battery for a few minutes, then connect it back. Turn on the car and let it IDLE for 15 minutes. Do not push the gas)
b. Check oxygen sensors / fuel cap
c. Make a new thread and talk about it...
d. Dealership (of course lasttttt option)
3. "Air Bag" light blinks...
Please post an answer
4. Please reply with more FAQ's
I hope that you find your solution here...
-ak
Old Jun 4, 2003
flotsamm's Avatar
To add to the above..
It looks like the TSB's in the lists I have are still online. Just paste this into a new browser: http://www.nhtsa.com/TSBScans/sbXXXXXX.pdf and simply replace the XXXXXX part with the corresponding TSB number from the list. I suggest you download them while you can!
Old Jun 4, 2003
HondaLuver's Avatar
Its a celebration bitches!
dam, i didn't know that much stuff was wrong with my car... don't let the ford people know this!!!!
Old Jun 4, 2003
ak's Avatar
ak
Retired Mod
Well, not ALL civics have the problems mentioned above.
I have a few, but definetely not 210+
None of the problems look "critical" you know? I'm sure that Ford's list is quadruple the size!
Japanese Automotive Engineering = #2 (After German & Italian...)
Old Jun 4, 2003
armageddon's Avatar
armageddon is an unknown quantity at this point
too late, I cant download them now!!
Old Jun 4, 2003
ak's Avatar
ak
Retired Mod
What are you talking about? His method does work, i just tried it for 2 tsb's...
Old Jun 5, 2003
Devst8n's Avatar
Devst8n is an unknown quantity at this point
Hey guys,
I am having a problem with the transmission on my 02 LX and its really hard to shift. 2nd gear grinds when its cold. There is a TSB for NHTSA but its for the 2001 and honda claims the 02 is not affected. They say its fine but my roomie has the identical car as mine and shifts and clutch feel is way different. I want to show them this and force some warranty out of them but I cant get access to the alldata TSB, does anyone have a copy of it?
Old Jun 5, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
"1. My "Main't Req" (Maintenance Required) light blinks / is constantly on?
If I remember this right,
Old Jun 9, 2003
mikek753's Avatar
mikek753 is an unknown quantity at this point
any where I can get TSB's for Civic 99?
tnx
Old Jun 9, 2003
AlpineWhiteM3's Avatar
AlpineWhiteM3 is an unknown quantity at this point
same sites... doh
Old Jun 10, 2003
komodomichie's Avatar
komodomichie is an unknown quantity at this point
sooo glad someone knows how to turn off that stupid "maint required" light!!
Old Jun 10, 2003
flotsamm's Avatar
Is there a place where I can upload all of the PDF's that I have so peeps can pick and choose the ones they want? Just to make it easier for some.. no worries.
Old Jun 10, 2003
mikek753's Avatar
Originally posted by AlpineWhiteM3
same sites... doh
how I can get the file names?
tnx
Old Jun 11, 2003
ak's Avatar
ak
Retired Mod
you gotta sign up and search for them...
Old Jun 12, 2003
mikek753's Avatar
Red face
I got the list:
Service Bulletins
TSB Number Issue Date TSB Title 00-088 NOV 02 Brakes - Brake Disc Refinishing Guidelines
02-052 AUG 02 Restraint System - Occupant Detection Initialization
00-095 MAR 02 Body - Moonroof Seal Squeaks
00-006 DEC 01 Suspension - Rear Suspension Clunk/Squeak Noise
98-061 NOV 01 A/T - In-Warranty Exchange Program
00-088 AUG 01 Brake Discs - Refinishing Guidelines
01-040 AUG 01 Engine Rear Main Oil Seal - Leaks
98-011 AUG 01 Keyless Entry - Transmitter
00-012 JUN 01 A/T - Harsh Shifts/Stays in 1st Gear/MIL ON/DTC's Set
00-064 MAY 01 Body - Windshield Molding Deformed
01-029 MAY 01 Engine Controls - DTC Capture and Downloading
00-004 MAR 01 Hood - Rattles on Rough Roads
99-002 JAN 01 Body - Driver's Power Mirror Vibrates
00-099 DEC 00 Wiring Terminal - Repair Instructions
00-088 NOV 00 Brake Rotor - Refinishing Guidelines
00-089 OCT 00 Supplemental Restraint System - Inspection
00-063 AUG 00 Special Tool - Chassis EAR(TM), Diagnostic Tool
99-053 JUN 00 Immobilizer Key - Key Code Duplicator
00-012 JUN 00 A/T - Harsh Shifts/MIL ON DTC P0370 & P0715 Set
00-003 MAY 00 A/C Idler Pulley - Growling Noise at Idle
99-018 APR 00 Required Special Tools And Equipment,
00-006 MAR 00 Rear Suspension - Clunk Noise
98-019 MAR 00 Audio Unit - Warranty Exhange/Out of Warranty Repair
00-015 MAR 00 Audio Unit with CD Player/Changer - Error Codes
00-022 MAR 00 Torque Converter Oil Seal - Installation Tool
00-025 FEB 00 Coolant Leak From Reservoir
99-073 FEB 00 Driver's Foot Rest - Popping Noise
00-007 FEB 00 Fuse Box Cover - Falls Off
97-009 FEB 00 Ignition Switch - Key Cannot Be Removed
98-079 FEB 00 Rear Hat Shelf - Rattle/Buzzing Noise
00-013 FEB 00 Rear Doors - Hard To Open
00-021 FEB 00 Windshield - Wind Noise (Whistle)
98-088 JAN 00 Instrument Panel Trim - Wool Felt Sticks Out
97-015 DEC 99 Service Publications - Availability & Ordering
99-089 NOV 99 Hood Release Handle - Broken
99-094 NOV 99 Poor Radio Reception
98-031 NOV 99 Aftermarket On Board Diagnostic (OBD) &pip;&pip; Tester
99-062 OCT 99 Paint Damage From Environmental Fallout
99-060 AUG 99 Windshield - Creaking Noise
99-030 MAY 99 Recommended Materials
99-029 APR 99 Malfunction Indicator Lamp (MIL) ON With Blow Fuse 15
99-025 APR 99 Rear Door Lock Tab Is Hard To Operate
99-010 JAN 99 Body - 1999 Paint Code Reference
98-089 DEC 98 Security System - LED Is Not Working
98-082 OCT 98 Windows - Bind or Come Out of the Run Channels
98-051 AUG 98 Special Tool Loan Program
how I can get file name based on that?
tnx
Old Jun 24, 2003
orion_squall's Avatar
hi,
I have door rattling problem. My car is 30000km now (not mile). I locate in Canada. Can I just go to any dealer in Canada and tell them to fix it? do I have to show them the TSB? will those TSB apply to Canada?
thanks
Old Jun 25, 2003
ak's Avatar
ak
Retired Mod
Originally posted by orion_squall
hi,
thanks
If the TSB is up on the first post, yes. Print it out and the dealership will fix it without questions. TSB applies to Canada also.
Old Jun 26, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
heres a list from alldata.com
http://www.alldata.com/TSB/24/012436AJ.html
Old Jul 4, 2003
Handsonme's Avatar
Fawk. My car is doomed.
It only had the fuel pump recall fixed. I believe my car has other problems. I am going to the dealer to get something fixed later this month anyway; perhaps I will check my stuff out before I go.
Old Jul 10, 2003
2k1civic.com O. G.
wheres the picture of the list of TSB's? i tried checking the website but it seems like you have to pay them like 40 bucks!!!.. and the other website is free alldata.com but doesnt show all of the TSB.
Old Jul 12, 2003
erica02civicCPE's Avatar
erica02civicCPE is an unknown quantity at this point
Won't let me anymore... gave me this retarded message.
>The American Honda Motor Company, Inc. has requested ALLDATA restrict access to Acura and Honda repair information by individual consumers. You will unfortunately not be able to register for access to Acura or Honda vehicle repair information, technical service bulletins or recalls.
We kindly request that all comments should be directed to:
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Please accept our apologies for any inconvenience this may have caused you.
Old Jul 28, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
always something wrong with cars
Old Aug 5, 2003
ak's Avatar
ak
Retired Mod
all cars..... the majority of our problems are minor though.
At least our engines don't randomly catch on fire!
Old Aug 11, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
This is the first time I have seen a TSB for the stalling/idling problem... courtesy of Pharoh :
http://www.7thgencivic.com/forums/at...postid=1292663
Old Sep 18, 2003
johnnyslil01ex's Avatar
Soon to be Mr. GST
johnnyslil01ex should not be trustedjohnnyslil01ex should not be trustedjohnnyslil01ex should not be trusted
sweet, by the time Im done with the dealer I'll have a new engine, lol. I got 90% of the problems listed.....wish me luck I got a warranty appointment this week....he he he...Im armed with my sword and my pen, ready to stop those ho's for building a shitty car I love.
John
Old Sep 18, 2003
I find honda dealers good...
as long as you are in the guarantee periode you can just go and tell them to fix anything
Old Oct 3, 2003
ThermalRD's Avatar
ThermalRD is an unknown quantity at this point
Those are interesting. Does anybody know if something like this exists for my 02-03 civic Si? I have the crazy rattling, vibrating BS when i drive in rain, and thru puddles. Exactly like what was mentioned in the original post. Except i have an Si? Should i try to explain this to the dealer? Im a little leary of this, because i also have a cat back exhaust on my car. Any help would be appreciated.
Thanks, Matt
Old Oct 4, 2003
Rufus's Avatar
does anyone have access to the TSB's for the O3 EX Coupe US model. If anyone has them download already shoot me a PM.
Old Nov 6, 2003
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
so wait wait.... for the mods or whoever???? i have the suspension noise rattle problem.... so what do i do to get it fixed for free/???? thanks
Old Nov 6, 2003
ThermalRD's Avatar
I solved my rattle problem. I started by going to the subaru dealer, then i sold the civic. Then i sold the exhaust. Now im selling my zigen wheels. I drove home a 2004 WRX. No more exhaust problem.
Matt
