Manual Transmission Speeds
Here's how fast our cars are going at a given RPM
For the manual transmission only!
Can a mod sticky this to help alleviate the weekly question...
-Mark
Edit: Fixed the Download, Stupid Dial up...
-Mark
Originally posted by Boilermaker1
You don't have drag factored in... so its a couple MPH off in every gear... we don't drive in a vacuum.
Then explain why the car doesn't do 125 in 4th... it only does about 110. Assuming what you claim the car should do, roughly 170MPH redlining 5th... but it doesn't, we all know it will barely do 130 with the wind behind you... The Civic Type R only makes it to 146 and there's no limiter, and it's got 73 more horse... Care to explain how that works if drag has no factor in this?
I think he's stating the maximum speeds possible in each gear period, wind does not factor in when u're just talking about how fast the wheel will spin at a given gear at redline. You might not make it there on stock, but if you boosted it but didn't change the tranny, those would be your max speeds in each gear.
It's a chart showing the speed you will be traveling at a given RPM in a given gear. It says nothing about a max speed. I posed this so people don't keep posting "How high does 3rd gear top out at". It can also be used as a comparison between the different cars transmissions. I know for a fact that the HX gearing is accurate because I own one, and have gotten up to 105 in 3rd gear. As far as the other gears, I have no proof, but the math is solid, and the gear ratios are the correct ones for our cars.
Drag only is a factor when determing the max speed of our cars, since I don't have the time to figure out the wind resistance and all that... that will have to wait till the summer.
The file is an Excell Spreadsheet. I had to zip it because of the 50k filesize limit.
beantech
Jun 15, 2015 07:09 PM
jackshepardjr
May 24, 2015 09:53 PM
