Sponsored by:
Sponsored by: CARiD
DEi Cryo System?
Old Jun 3, 2003
robbclark1's Avatar
Retired suspension supermod.
DEi Cryo System?
Has anyone heard of these? I recently was told about them. They are like nitrous but with O2 instead.
http://www.designengineering.com/cry...ted_items.html
Old Jun 3, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
No, but if i'm hering it right, it's waay better than nitrous. Nitrous releases the extra oxygen for combustion, but pure oxygen- wow!!!!
Old Jun 3, 2003
hothondacivic02's Avatar
hothondacivic02 is an unknown quantity at this point
no a cryo system is to cool your intercooler it sprays really cold
02 on your intercooler to keep it cold .
Old Jun 3, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
Cryo = cold. This setup cools various things depending upon your application. It cools intake air, it cools your fuel, and can cool your intercooler.
If you've ever used one of those "canned air" cleaning sprays on your dusty computer, then you know how this setup works. The "Can" gets pretty cold as the liquid expands into a gas. The bottom line is that as a gas is compressed it heats up, it then loses its heat and when it re-expands it is now colder. This happens in your fridge, in your AC etc. etc. etc...
Old Jun 3, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
if you have a tank full of pure oxygen gas in your car, and you crash and catch on fire, you are screwed. The Nitrous will not burn unless under high pressure and temp (kinda like in your engine), but the Oxygen will feed whatever fire it finds. Look at the Apollo 10 capsule (i think), it burned because the fire was fed by all that O2.
I am not saying it wont work, because it will work rather well. But i just think its a little dangerous.
Old Jun 3, 2003
robbclark1's Avatar
Well they have a bunch of different systems. One system is a shot, one system is a air intake cooler, one is an intercooler cooler, and one is a fuel cooler. I think basically they are going on the point that the cooler the air/fuel mixture is, the more HP.
Old Jun 3, 2003
The reason why NOS has the Nitrogen component is exactly like Catalyst described. PURE oxygen is very dangerous. Generally speaking things have a certain temperature that they combust at. The more oxygen in the environment the lower that combustion point. I don't know what temp gas would combust at in a pure oxygen environment but it might actually be less than normal room temperature!!!
This is all irrelevant however, THAT system above has very little similarity to a NOS system. They function completely different and accomplish completely diferent things.
Old Jun 3, 2003
EXACTLY. Those systems are designed solely for this above stated purpose.
Old Jun 3, 2003
One other thing to point out: This system does not use O2. It uses CO2. Go grab your CO2 fire extinguisher and spray it on your hand*. See how long you can hold it under the spray. After this little experiment you'll know exactly what is going on here.
*disclaimer- may be hazardous to your health (and hand)
Old Jun 3, 2003
robbclark1's Avatar
I thought it was CO2 but it never really states clearly. We use CO2 to euthanize the animals in our lab and I know it get cold. I just wanted to some feedback on what people thought of the product. I would never get it for my car.
Old Jun 3, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
so what would be better, nitrous or this stuff?
Old Jun 3, 2003
If you mean "Wich adds more power" then the answer is Nitrous. This Cryo cooler is like running your car on a really cold day.
Common sense suggests that the three components here would probably only really help if your car is under boost. By lowering the intake charge temp and fuel temp you increase fuel and air density (more power) at the same time reducing the temperature let's you run higher boost by lowering chances of detonation.
Old Jun 3, 2003
Catalyst's Avatar
actually, with our cars, you want the fuel to be warm, because it vaporizes better. We tested it on my crx, and hot fuel made more power. I know that cold fuel has more punch, just like cold air, but the fuel is easier to vaporize when it is warm.
Old Jun 3, 2003
Catalyst's Avatar
of course, i am talking about under boost. I am sure that cold fuel is better for NA cars.
Old Jun 3, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
It's Carbon Dioxide.... and its in fire extinguishers. This stuff is a fire retardant, and you want fuel to burn don't you? ... kinda contradicting to put it in your engine...
Old Jun 3, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
well most of the air your car takes in is made up of co2...
Old Jun 3, 2003
Jap-Euro Fusion
Air is 78% Nitrogen...
Old Jun 3, 2003
Originally posted by Catalyst
...the fuel is easier to vaporize when it is warm.
That makes sense. You may be able to squeeze more cold fuel into a given volume, but if it doesn't burn as well there goes the efficiency. I can see that there is probably a given temp that gives you maximum density for minimum loss in atomization. I guess, too much in either direction and you start to lose that efficiency.
Old Jun 3, 2003
ohmysac's Avatar
derrr..... i shoulda paid more attention in science class.... but my point still stands
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
