Rough Idle
Old Jun 1, 2003
kbradner's Avatar
kbradner is an unknown quantity at this point
Rough Idle
When i crank my car up in the morning, 01 ex, it starts up fine but when it starts to warm up it idles real rough like your in a 454 or something for a few seconds then its fine. Can someone tell me why it would be doing that???
Old Jun 1, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Re: Rough Idle
Idle RPM may be too low. Is it like at 500rpm?
It should be around 750-800rpm.
Adjust the throttle cable (see DIY section)
Old Jun 2, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Re: Re: Rough Idle
Mine idles fine at 600, since the day I got it 2 years ago. 800 seems kinda high... may use more gas too.
Old Jun 2, 2003
ak's Avatar
ak
Retired Mod
Mine is at 600 and it shakes like a ****.
It could be the oil no? This cheap generic oil makes the engine sound so harsh.
I used to idle at 500 with Mobil 1 Synthethic Blend without any rough shaking.
Old Jun 2, 2003
flotsamm's Avatar
The brand of oil shouldnt make much of a difference and as long as its the right viscosity. Could be that your TPS(trottle position sensor) is marginal, or even your CTS(coolant temp sensor). I've even read that it could be your ECU code needs to be updated. Have you tried resetting the ECU? Disconnect your negative battery cable for a few minutes and reconnect it. Right down your radio stations if you care. There's a section in the owners manual that tells you how to properly do this so your ECU re-learns your driving style. Mayb not fixe it, but worth a try.
Old Jun 2, 2003
Vytas's Avatar
Vytas is an unknown quantity at this point
All you guys probably have 2001 civics. I heard that ECU unit is messed up on some of them. My advice, if the car does not shut down, keep on driving, if it does - take it to the dealer and the first words out of your mouth should be WTF!
Good luck
Old Jun 2, 2003
2k2EXCOUPE's Avatar
TUCKIN 19s
mine idles at like 900....wtf!?!? i thought that was normal
SimpleUser
Apr 24, 2021 02:54 AM
lyanreindecker
Aug 20, 2015 09:15 PM
GritzNGravy
Aug 19, 2015 03:03 AM
alaga
25
Aug 13, 2015 04:42 PM
1khilari
Jul 9, 2015 08:12 PM
