dealer aim my lights for me? i have switched my bulbs.
Old May 28, 2003
AR's Avatar
AR
e-married to daydreamer
Do you guys think my HONDA dealer should aim my headlights for me? I want them aimed and set for the factory setting. I figured it would be best if they did it themselves and me not sweat my ***** trying to figure it out.
Will it be an arm and leg service charge though?
Will they void anything on my warantee?
I have switched to "hyper white" bulbs, Sylvania silverstars and piaa extreme whites, for the parking, but stock …un-cleared housing now.
*NOTE: Let's not make this an argument of stock bulbs are brighter than hyper whites.*
Old May 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
ARE YOU SERIOUS... go out to a car park like 40 feet behind it and angle the lights at the license plate... all u need to do is have both even... its not hard .. its turning a screw almost.
Old May 28, 2003
AR's Avatar
AR
i curious to know if maybe Honda will do more than just park it forty feet from a parked car and visually check if it's lined to the liscense plate.
Old May 28, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Call them and ask.......
Old May 28, 2003
AR's Avatar
AR
might as well. but i am still wondering if anyone's done this.
they claim they (honda) need a technician in to aim the lights and they're booked until next week monday.
Old May 28, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
if its free do it... otherwise....DIY
Old May 28, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i don't even think u need to aim them if you only switched out the bulbs. now if you took off your headlights to clear them and they look off, then that's another story
Old May 28, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
I think I called the dealer to see about this 2 years ago when I bought my car. The guy said that our headlights have a auto leveling mechanism in them. I didn't beleive him though
Old May 28, 2003
tripledoublegs's Avatar
Euro-Spec
I don't think they do. What the hell is it? A BMW?
Old Jul 20, 2003
SedanDriver's Avatar
SedanDriver is an unknown quantity at this point
No such thing on our 7th gen. All you do is use a 10mm wrench and turn it to the right to go down and turn it left to go up. That's what I did. Didn't have to mess with the left and right.
Old Jul 20, 2003
XtremeJM's Avatar
my lights are all whacked....oh well, i can still see at night.
Old Jul 20, 2003
Bellz's Avatar
"Park the vehicle 25 feet from a wall on a level surface. Measure the distance between the center of the light and the ground. Place a horizontal mark on the wall at that height.
Visual aim is made with the center of the driving beam hot spot 1.5 inches below the lamp center at 25 feet with the lamp facing straight forward."
...i keep that and other lighting info in my diy (see sig.)
Old Jul 20, 2003
After I cleared my lights, added new bulbs, and put a sub in the trunk, I took it in for reaiming. They charge $40 to do this, and I think they have a machine or aiming device that they use. Just take it in.
Old Aug 3, 2003
TOOLOWCIVIC's Avatar
I know its just a screw to turn but I dont know where exactly is it Can someone post a pic of the screw to adjust the lights. I have HIDs and they are aiming to high.
Old Aug 3, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
dude, it's a screw. it takes about a minute to do. there is only one adjustment per light. get off your *** and do it.
Old Aug 3, 2003
Mags's Avatar
I have a picture of it if you want. It's just the oval looking hole on the light itself. It's in a black bracket. Just put a phillips screwdriver in there and turn it. Your lights can only be adjusted up or down. Tonight, go park about 20 feet away from a wall and get out of your car (make sure your lights are on and ppo your hood). Open your hood and you will notice that these holes will sort of glow. Just put in the screwdriver and turn it up or down and make your light pattern so that it is just alittle bit lower than the actual height of your headlights. There is NO need to spend $65 to have the dealer do 1 minute of work with one hand tool for you. It's easy.
Old Aug 3, 2003
pheaton's Avatar
A descendant of 2k1civic.com
hrm. . I haven't heard of such a problem. . unless my lights are off and I don't know it. I cleared mine and don't think that mine have a problem. . Hrm . I'll have to check it out.
Old Aug 3, 2003
Well I had took off my lights off for over a year cus I had projectors. Now I put them on and installed HIDS. Thanks Mag. I figured it out.
Old Aug 3, 2003
cryption's Avatar
2003 Nissan Frontier
just changing the light bulbs wouldnt requier it to be aimed ... i changed mine no problem as im sure many have
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
wawacito
Nov 5, 2001 03:32 PM
