Who has HID in stock TYC's???
Old May 20, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Just as the topic states. I don't want to mess with my TYC's by trying to retrofit A6 projector lenses. I would rather just get the plug and play kit from Phillips. I also want to see pictures of HID in stock TYC and I want to know if there are any problems that people are having with them. Thanks
Old Feb 15, 2004
silverem2's Avatar
me, too, id like to see how just regular unmodded tycs do with hid
Old Feb 15, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
pm Impulse
Old Feb 15, 2004
silverem2's Avatar
ok, but anyone who has them, post pictures, note, this is for only people with stock projectors
Old Feb 15, 2004
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical...Subforum: Lighting
Old Feb 15, 2004
JayFReaZy's Avatar
I've herd h1 HID's do not fit directly into the tyc/halo projectors. There will be some modifications reguarless. I think the h1 hid bulb is a lot longer than a regular h1 halogen bulb. People said you have to sand down certain areas of the housing in order for it to fit. Do a search, i think there are a couple topics on it.
Old Feb 15, 2004
ImPulse's Avatar
ok... HIDs in TYCs/Aftermarket projectors.
1) Aftermarket projectors = Shitty light output (IMO). The projectors are made outta **** glass (basically a magnifying glass). There is a piece of metal in the projector called a shield (shitty made). < Ill take pics if u guys want.
2) Aftermarket HIDs = $200-400+, and when bulbs burn out you can basically only buy "Vision HID Bulbs" (That will break/burn out after a couple of months). Bulbs = 100$?
3) OEM = Well... I dont have to get into that
VoiceOfID had aftermarket HIDs in his projectors and took comparison pics between them and OEM HIDs (Ithink) anyways, with aftermarket hids and aftermarket projectors you WILL have MAD ****ing glare and, cops/people will be pissed off at you.
Old Feb 16, 2004
silverem2's Avatar
so all in all, change the projector before you go hid
Old Feb 16, 2004
Voiceofid's Avatar
End Bringer
now, before i go any further, i've had people say what i show is faults on the tyc projectors, because i aim them wrong or whatever.. so... make your own judgement
h1 hid, 4500k, stock tyc
h1 hid, 4500k, valeo
Old Feb 16, 2004
silverem2's Avatar
well, thats from two totally different angles, do you have or does anyone have garage pictures?
Old Feb 16, 2004
A03's Avatar
A03
A03 is an unknown quantity at this point
The opening for your bulb is very cramped in the TYC projector. I'd imagine that MOST HID retro bulbs will not fit even if they were made for H1. The return wire will have to be physically touching the projector (or very close to it) to fit.
I have the stock TYC projectors sitting on the shelf, but have never tried to put a retro H1 bulb into one of them. I can tell by looking at it, that it will not be easy. The pattern is not good, but I have definitly seen worse.
Old Feb 16, 2004
Voiceofid's Avatar
End Bringer
driverside, tyc catz hid h1 4500k
passengerside, valeo catz hid h1 4500k
Old Feb 16, 2004
silverem2's Avatar
the beam pattern isnt THAT bad, what modding did you have to do to put hid in there Voiceofid?
Old Feb 16, 2004
Voiceofid's Avatar
End Bringer
to me it was so bad that i had to do the retro
it invloves removing the tyc projectors and replace with the oem style projectors
different memebers did it differently, i cant really tell you how i did mine. because chances are you wont do it the same way. i tried to explain it to jay and he didnt undrestand what i did at all
the cut off in the pic is created by the valeo on the passengerside
the driver side tyc's only light was that yellow arc
Old Feb 17, 2004
ImPulse's Avatar
because it doesnt make any sense! Haha, I just dont get how u did it
Old Feb 17, 2004
silverem2's Avatar
ok, I will have to think for a while then, it seems to perform ok with regular bulbs. that will do till i decide
Old Feb 17, 2004
ramoMan's Avatar
ramoMan is an unknown quantity at this point
so it's possible to purchase a hid kit and plug and play into the tyc projector's, because the cut off patter is pretty nice.
Old Feb 17, 2004
Voiceofid's Avatar
End Bringer
what cut off pattern?
out put of the tyc projector
out put of the valeo
tyc projectors
valeo
Old Feb 17, 2004
silverem2's Avatar
if you look at the two pictures of it shining down the road, it looks like the first one shines brighter
Old Feb 18, 2004
Voiceofid's Avatar
End Bringer
then believe what you want to believe, i put down my opinions, it's your choice to look farther or not
Old Feb 18, 2004
silverem2's Avatar
im not arguing your opinion, Im just saying from the LOOKS it looks like it in the side view picture. In the picture from the driver side, it looks like the valeo is farther, but all in all, if you cant afford a conversion(after spending all the money into hid) getting that kind of light output is acceptable over stock.
Old Feb 18, 2004
Voiceofid's Avatar
End Bringer
i would have rather had stock
at least i would have been able to see in the rain
Old Feb 18, 2004
Booohahaha's Avatar
BAD MON
do the HID H1 harness plug in into the H4 harness?
Old Feb 18, 2004
silverem2's Avatar
no, you need to get a h4 hid kit if your planning on keeping stock headlights
Old Feb 18, 2004
Booohahaha's Avatar
BAD MON
noo i have angel eyes projectors and i just got my hands on H1 hid and i just want to plug it in.
what else do i need?...
do i splice and connect the projector's harness? if not, where do i get it?
Old Feb 18, 2004
ImPulse's Avatar
well if your headlights use h1... and if your kit is "plug n play" then it should have an adapter with it... so u shouldnt have to splice anything.
There is nothing attached/plug thingy that goes into the H4/OEM harness? o_O
Old Feb 18, 2004
ramoMan's Avatar
Voiceofid, the cut off pattern against the garage doesn't look soo bad, but i guess it doesn't reach as far? oh well, the reason i don't want to use valeo projectors is because if i f*ck up, my tyc headlights have gone to waste, and it seems like a very difficult task. I'll see what I can do
Old Feb 18, 2004
Booohahaha's Avatar
BAD MON
hmm...thats cool i got it to light up.. through trial and error
Old Feb 18, 2004
JayFReaZy's Avatar
^ can ya post pics of what the HID light output at night is like with the halo projectors?
Old Feb 18, 2004
silverem2's Avatar
ya, post pictures!!!!!!!!!!!!!!!!!!
