What kind of ATF should I use??
Well, I have a 2001 civic auto. and it has around 34k miles and i drive my car pretty hard so i need to replace my atf. but i need to know which kind is the best and where can i get it??? I heard some people using mobile 1, the honda kind, and quaker state. thanks
I just changed mine to Honda's Z1 ATF. Honda has different specifications for its ATF than other manufacturers. Most other manufacturers use Dexron III type ATF, while Honda and Chrysler use their own formulation.
alrite thanks but could u guys give me more info. on the synthetic kind?? and well there is a problem buying the honda kind b/c then i have to drive about an hour away to get to the honda dealer and buy the atf fluid.
Here is a good link from an Acura Vigor enthusiast club. The information is quite relevant.
http://pw1.netcom.com/~gentile/Vigor/Timely0102.htm
Its a celebration bitches!
Im using Motul synthetic ATF and my car runs perfectly, you should be changeing your ATF every 30,000, I change my motor oil every 3,000 with Motul Synthetic. its one of the best brands out there
From the Vigor site...
"Second, Acura recommends using genuine "Honda Premium Formula Automatic Transmission Fluid or an equivalent DEXRONŽ II Automatic Transmission Fluid (ATF) only." Many club members reported harsh shifting problems that were fixed by changing over to Honda's ATF. Apparently, the difference is significant enough that we recommend using only genuine Honda ATF."
Zygrene
Mar 22, 2016 12:36 PM
Touge
Sep 18, 2015 12:13 AM
