what amps???
Old May 9, 2003
Cree01's Avatar
Cree01 is an unknown quantity at this point
what amps???
I am buying 2 kicker comp vr's and mb quart 6.5 components along with a pair of mb quart 6x9's. How many watts and channels do i need for this??
Old May 10, 2003
LudlamTheory's Avatar
i boogie for the raindrops
you dont NEED any watts. you could do all that with anywhere between 3 and 12 channels. its all dependant on what you wanna do, how much money you wanna spend, etc. that sub will move with as little as 10 watts or as many as 500-700... same for the quarts.
Old May 10, 2003
Cree01's Avatar
That doesn't help me much. I want to spend what ever I need to have the subs slam and the other speakers to be loud the subs go up to 500 watts rms and i'm not sure about the other. I just wanna know how many channels I need per amp for the subs and the mids?
Old May 10, 2003
what model mb quarts to begin with.
secondly, with the sub amp you just need to find something that gives you the amount of power you want at the ohm load youll have.
you could spend anywhere between 100 and well overr a grand.
as to the mb quarts,
we can do a 2 channel that you can bridge your speakers to, cheaper, but you wont be able to fade from front to rear,
you can do a 4 channel so therefore you can fade from rear to front but more expensive,
your other option is to only amp the fronts, run the rears off the deck with a 2 channel. if you then decide you want your rears amped, you can just merely add another 2 channel.
for these options again you can spend between 100-200 to well into the multi thousand dollar range.
Old May 12, 2003
Cree01's Avatar
A dude told me to get a 4x75 amp for the quarts and 600-1000x2 for the kickers. Does that sould about right?
Old May 12, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
It will work fine, but again, it's all in how much you want to spend and how loud you want to go. What model Quart's do you have? I'm running 500 watts to my Quart PSD 216's. 250 watts per-side. No rears. If you have PSD's, then 75 is alright, but you definately arent playing them to their maximum potential.
As far as $$, my highs amp cost me $700...its $1100 retail. It's 4x125, and I bi-wired it. (2 channels to each side of the fronts) A cheap 4x75 amp could run you $100-$200. You will go loud, but not ear piercingly. (quarts are not particularly efficient). You also will pay for cleaner power, more tuning options, stuff like that. Tell us what you want for sound, and what model your quarts are. Then we can help you.
As far as the kickers, a 1000x1 amp would be fine.
Old May 12, 2003
WhiteRabbit's Avatar
OT, hifonics XI plympus, mystic?
back on topic, 1000 rms is defniiitely approaching the maximum amoun tof powe ryoull wanna give yrou VR's. 600 peak watts would eb the lower level, but dont think they wont get loud off little power as well!
jsut be sure yrou amplifier puts out its power at a configuration that you cna wire yrou subwoofers to.
and 75x4 powering each corner is more than average amount of power as is, i think you will love that.
sounds like a plan to me!
Old May 12, 2003
mystic, biwiring a set of components only has you playing 250 watts at the exact point of crossover. probably 3500 hz.
Old May 13, 2003
i thought he meant biamping, where his tweeters adn midwoofers were on separate channels?
each speaker woudl get 125 rms in that case.....
Old May 13, 2003
hmm... did he? did you?
Old May 13, 2003
Mystic3030's Avatar
I have a PPI PCX4125.....one channel to the tweet, one channel to the mid on each side like WR said. It's 125x4 RMS.
Old May 13, 2003
Cree01's Avatar
Okay I got some more info. The fronts MB Quart DSD Reference 6.5" 2-way. And the rears are MB Quart DKC 169 2-Way. I found a Kicker amp KX300.4(2 Ohm @ 4x75). And another Kicker amp KX800.2 2 channel with the Kicker comp VR 12'S. Does this sound like a good set-up?
Old May 13, 2003
12W6v2's Avatar
12W6v2 is an unknown quantity at this point
Mystic3030....Does your MB PSD tweeters shut off (go into protection mode) at high volume?
Cree01.....If you want 75 watts x 4, then you will need to get the Kicker KX600.4 since you will be pushing the speakers at 4 ohms...... The KX300.4 will give you about 37 watts x 4 @ 4 ohms.....The amp for the subs is fine.
Old May 14, 2003
Cree01's Avatar
I havn't installed them yet but I found that amp for 229 and it's 4x150at 2 Ohms. Is that right and at 4 Ohms it said 300x2?
Old May 14, 2003
Mystic3030's Avatar
No, the MusiComp crossover that comes with the PSD's has a light filament in it that absorbs excess power to keep the tweets from blowing instead of shutting off. If you really overpower them, the light will blow like a fuse, shutting off the tweets and then you just need to replace it. I have yet to do that though, I can turn my HU all the way up and it is unbearably loud in the car, with no distortion. I am at the limit for those speakers though. I beleive they are 130 watts RMS, and i'm giving them 250.
It's all in proper tunning though....like I said, the light filament barely glows when I crank it, when I was first experimenting with it, I could get it to light up all the way, almost popping, but that was with imporoper gain settings and stuff....Now it's great.
Old May 14, 2003
cree, something isnt right about yrou spces. double check them.
yoru speakers are at 4 ohms, so forget about any powerrating at 2 ohms. like, completely. if it doesnt say @ 4 ohms, then you dont have to even care about it.if its 37 watts at 4 ohms stereo, most likely its 150x2 at 4 ohms mono. id doublecheck, for sure.
Old May 15, 2003
Cree01's Avatar
Forget this I'm just gonna go to AMPT and have they set me up with what I need. Thanks for the help.
h4ldol
Apr 24, 2017 08:16 PM
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
Mc7602
Sep 17, 2015 02:01 PM
redcloud
Sep 7, 2015 01:45 PM
