alternator?
Old May 7, 2003
Goatboy's Avatar
Goatboy is an unknown quantity at this point
alternator?
hope you guys can answer a question for me. I read that you can put a switch on the field of your alternator to turn of the drag when needed. this could possibly free up some horse power when you want. Is this possible, will this hurt anything? If all good please make a DIY thanks.
Old May 7, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
i think the only way you can turn off the drag of the alternator is to figure out a way to disengage its belt. sounds like a complicated DIY
Old May 7, 2003
Slumpert's Avatar
Slumpert is an unknown quantity at this point
Humm, I wonder if fitting a AC type clutch would be a option, and if it really would make any difference.
Old May 7, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
you would get what. perhaps 2 hp tops on a good day if you did that. and how long will the car run with the alternator turned off, not very. my cable came loose and my car went all of about 2 blocks with out the alternator and broke down. I had to call a friend to get a jump. and even then its a tight fit to get anything in the engine bay in that area. I wouldn't do it, sounds like trouble.
Old May 7, 2003
Spazbitte's Avatar
Spazbitte is an unknown quantity at this point
Its going to be tough to do. If you are worried about parasitic loss just scrap your ac and whatever sound you have in your car. Probably bigger gains for less of the hassel and it does not cost anything to pull things out.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bonobo
Oct 2, 2015 06:58 PM
ken4444
Sep 30, 2015 07:37 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
