help with header fast
Old May 6, 2003
Deception2k1civic's Avatar
My car is goin to have a new look!!!
Deception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura aboutDeception2k1civic has a spectacular aura about
damn i just put on the dc sports shorty header and i over torqued the upper left nut and it broke off. any suggestions on how i would go about taking it off? will it be bad to drive like that? also the car is very loud. i think ill have to go back and tighten all the bolts.
Old May 6, 2003
CarbonFly's Avatar
This is why you have to use a Torque wrench on stuff like this. Take the car to your local auto shop and see if they can remove the broken bolt and replace it.
Old May 6, 2003
thanx for the info. will it be bad if i drive around like this until i get it fixed?
Old May 6, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
should be ok, if its not to far
Old May 6, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
Yes it will. You are bound to atract cops & get busted!! (if it is too loud)
It won't cause any other damage, though.
Old May 6, 2003
thanx for all the replies. i took off the header and lucky for me i was able to take the broken bolt out. i read in another post about taking the metal washer or whatever it is off the stock header and put it on the dc sports one. everything is all good.
Old May 6, 2003
xtiszx's Avatar
Cracka
great to hear man,
Old May 6, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
You can also use a tap to redo it. I wouldn't do that if I were you unless you know what you are doing. Any hardware store will have the parts though.
Old May 6, 2003
Vytas's Avatar
Vytas is an unknown quantity at this point
I had similar problem. I was driving without a bolt. Nothing happened , but mechanic told me , if I would continue driving like this, I would screw up my engine!. first, the super hot air would go out from that coner bit by bit. It would burn the hell of your gasket, and start burning your aluminum head. I am not a mechanic, but believe that guy would not just talk sh*t. So you could drive to mechanic, but I would not suggest to anyone to continue on driving without a bolt.
Glad it is all over...
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
