DIY Air/Fuel Gauge
Old May 2, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
DIY Air/Fuel Gauge
Aight... I'm sick of seeing this asked. It gets asked like 3 times a week and no one seems to want to search. So here... Sticky and Bold this so that no one can miss it.
Open the hood. Look straight down the exhaust manifold. There is a plug with a bunch of wires going to it just under the header. Thats your O2 sensor. Trace the wires back to the grey connector plug near the engine block (over on the right side, under the radiator hose). Slide back the wire shroud so you can see the wires (4 of them). Put a tap splice on the BLACK wire between the O2 sensor and the connector.
Run the wire inside the car. I recommend you not run the wire attached to the gauge through into the engine bay. It won't reach and it'll mean you'll have to splice the wires together in the engine bay. You'll be better off joining them inside the car so you minimize the exposed wire. Attach the wire you spliced into the O2 sensor to the purple wire on the back of the gauge. You need to find 12V and Ground. The Yellow/Green stripe wire that goes to the Cig lighter is 12 V, there is a screw behind the lower dash panel (w/ the lighter in it) that is a ground post, or you can run a ground wire in from the engine block (I did this). Hook up power and ground to their respective wires and thats it.
The gauge will oscillate back and forth between rich and lean. Don't expect it to stay in one place. It will completely disappear if you're moving and you take your foot off the gas (good old ULEV in action), and don't be surprised if it favors the lean side rather than rich (ULEV again). It should go rich if you floor it.
Old May 2, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
good diy!!!
Injen
Old May 2, 2003
Vinh's Avatar
Re: DIY Air/Fuel Gauge
[QUOTE]Originally posted by Boilermaker1
Does anyone know how to do a DIY on the Air/fuel ratio gauge?
Old May 2, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
so what connector are you sopost to hook to since my dx has 2 oxygen senor hook ups? And there both located right next to each other.?
Jeff
Old May 3, 2003
RoadRunner's Avatar
good deal i copied it to my comp so i can use it later when i do order my gause, thanx for the help
Old May 3, 2003
2001civ's Avatar
2001civ is an unknown quantity at this point
I'm putting this to the test next week when my gauge gets here. I just need a good place to mount it.
Old May 8, 2003
civicgeek's Avatar
civicgeek is an unknown quantity at this point
Hey Thanks!!
Would try to take a look at my engine bay soon!
Old May 12, 2003
EM2HK1's Avatar
EM2HK1 is an unknown quantity at this point
hey Boilermaker1 i noticed ur signature pic with ur car and names of some companies on the side. I noticed u have Custo as one of them. im kinda curious to know if Cusco makes anything for our cars? i always thought they didnt have anything for our cars, but maybe im wrong.
BTW ur car is really nice!! i love ur rims
Old May 12, 2003
Jap-Euro Fusion
The DC5 rear strut bar fits like a glove...
It bolts into the frame rail in the trunk too
Old May 13, 2003
EM2HK1's Avatar
oh i c, nice! maybe ill look into it
Old May 18, 2003
no's Avatar
no
no is an unknown quantity at this point
If all you have in your car is a cold air intake will those Air/fuel gauge really do anything for you or not really?
How much more stiffer dose your car feel after putting the DC5 rear strut bar? How good of a company are they? Im looking for a rear upper strut bar but Im not sure where to get it from.
Old May 18, 2003
Jap-Euro Fusion
Answer to question 1... It helps me realize how bad the stock fuel map sucks. And it makes for a nice conversation piece.
Answer to question 2... it makes a difference... and Cusco is one of the best JDM suspension tuners out there.
Old May 19, 2003
no's Avatar
no
Where did you find the cusco rear upper strut bar Iv'e been looking all over the net and I can't find anything?
Old May 19, 2003
Jap-Euro Fusion
RSXmotorsports.com will get one imported for you from Japan. It takes a couple weeks and it's not cheap.
Old May 19, 2003
no's Avatar
no
thank you,
all Iv'e been getting are japan pages that I can't read
Old May 27, 2003
hyperhonda2k2's Avatar
Tempus Fugit
hyperhonda2k2 is an unknown quantity at this point
cool
Old Jun 8, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
nice diy
Old Jun 20, 2003
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
added this to the DIY section
Old Jul 27, 2003
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
hey
i installed my AF guage today but it keeps reading Rich
when i cut the car on and when i drive.
it doesn't move at all
did i hook it up wrong or is something wrong with my car
any help would be appreciated
thanx
Old Jul 27, 2003
Jap-Euro Fusion
Make sure the gauge is grounded... If it's not.. it'll read full rich.
Old Jul 27, 2003
deeznuts's Avatar
deeznuts is an unknown quantity at this point
which o2 sensor wire did you use and alos which o2 sensor. i can't remember the color of the wire but you need to test the wire for voltage. it should be 1. the only 0-1 volt wire 2. the only wire that changes voltage as the engine revs. the o2 sensor under the hood is NOT a 0-1 volt. i used the one on the cat (2001 ex). just test the wire and you should be ok. 1 in 4 chance.
Old Jul 27, 2003
i figured it out
the splice into the O@ sensor wasn't deep enough
so the rich( green light) was pretty much just showing power
working just fine now
thanx for the quick responses thou
it is really appreciated
Old Jul 27, 2003
reytito's Avatar
hey boiler or anyone else...what gauge wire did you use for the wiring?
Old Jul 28, 2003
Jap-Euro Fusion
I used 18... That seems to be what the sensor is wired with, but the ECU wires look like 22 so somewhere in that range should be fine.
Old Jul 28, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
I used 18 as well, thanks again to Boilermaker for all the help when I needed it.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
speedlever
Sep 24, 2015 07:18 PM
