can't close carbon fiber hood all the way
Old Apr 29, 2003
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
i just bought a c-wings carbon fiber hood and when i tried to close it, i won't shut all the way. i did a search and found a link, which did not work, which was sopoused to be about changing some spring in the latch to make it fit. does anyone know what spring to change? also, are there any other ways to make it fit.
btw: the hood is a c-wings hood. i tried to return it, but F**king gtp said they won't take it back or exchange it.
Old Apr 29, 2003
RedDragon333's Avatar
is there anything worng with the way it looks or the fitment? I was thinking about checking there hoods out but i havent seen them. Do they have a under skeleton and rolled edges?
Old Apr 29, 2003
FALKEN's Avatar
Civicforums Junkie
did you try the hood levelers??
they screw in and out to adjust the height of the hood in the front...maybe they are too far out for this hood compared to oem (try turning them clock-wise all the way in and close hood)...if that works, then adjust them counter-clock-wise to align the hood to the fenders and so it still closes
Old Apr 29, 2003
my2k1vic's Avatar
dude, stay away from there hood! it comes with no trim piece, hood has buff marks everywhere, underside has paint marks they even covered holes with tape and painted them over! the hood also has a gap between the passenger fender and the hood. email me at bidwal_j@sbcglobal.net if you want to see pics of it.
Old Apr 29, 2003
my2k1vic's Avatar
where are they loctated at? haven't tried this yet.
Old Apr 29, 2003
[QUOTE]Originally posted by my2k1vic
[B]dude, stay away from there hood! it comes with no trim piece, hood has buff marks everywhere, underside has paint marks they even covered holes with tape and painted them over! the hood also has a gap between the passenger fender and the hood.
i feel for ya man, your not putting that ish on your ride are you?
Old Apr 29, 2003
my2k1vic's Avatar
[QUOTE]Originally posted by RedDragon333
[B]
i have to, at least for now, if i can't return it. anymore help on closing the hood would be great.
Old Apr 30, 2003
WhiteRabbit's Avatar
we had this exact same problem with my buddies carbon hood on his 99 EX.
as it turned out, after much work trying ot move aroudn the latch, it turned out that the bar on teh carbon hood was far larger than teh stock hood latch. so it PHYSICALLY wouldnt go in.
i dunno if this is yrou same problem..
the worst thing to do to get it to fit would be to notch teh piece. i suggested this, and found out that it wears the latch faster, till the hood eventually fails, and goes flying away.
the guys eventually had to notch teh stock latch inside the engine compartment, did it with an air saw, nothing else would fit, and went through several blades cutting the hardened steel.
good luck man, it took us several hours ot fit it in.
Old Apr 30, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
take the latch out and use hood pins
Old Apr 30, 2003
my2k1vic's Avatar
i hope i don't have to go through all that. the hook latchs at the first lock, but doesn't go down any more.
Old Apr 30, 2003
hoievvy's Avatar
hoievvy is an unknown quantity at this point
This happened to mine from kaminari, it would shut passed the saftey first latch but not all the way down. I had to bend the latch on the car back (just by hand) and look with a flashlight to see the two pieces match up.
Old Apr 30, 2003
my2k1vic's Avatar
cool, i'll try that too. was that all you had to do?
Old Apr 30, 2003
my2k1, sounds like youve got his exact problem. if bending it works on 7th gen, more power to ya, thats definitely preferable if just as reliable to our fix, cause it was really really really really really a pain for us.
Old Apr 30, 2003
my2k1vic's Avatar
thanks for your help guys, looks like i fixed the problem! i just removed all the rubber pieces that support the stock hood ( i guess those are the hood levelers because you can raise those up and down). now i can close the hood all the way down! it still sticks up a little from the sides, but thats only because i don't have any pins to push it down more. once i install the pins, everything should be fine.
Old Apr 30, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
All i did was a little bending on the latch and it worked
Old May 1, 2003
mike0404's Avatar
mike0404 is an unknown quantity at this point
i got my CF hood about a year ago..and now it looks like ****..i hate CF hoods..but maybe the new ones with sun protection are better...
Old May 1, 2003
FALKEN's Avatar
Civicforums Junkie
so it worked for you??
Old May 1, 2003
my2k1vic's Avatar
yes falken, it worked! thanks for your help. adjusting them didn't help, they were all the way down to begin with. i just took them out and now the hood fits good, just need pins now to push it all the way down, but atleast it now locks all the way.
Old May 1, 2003
FALKEN's Avatar
Civicforums Junkie
good...glad i could help out by pointing you in the right direction
Old May 27, 2003
97dsmbishi's Avatar
97dsmbishi is an unknown quantity at this point
just one key note about the sun damage etc.
i can understand that.....if you don't have a garage (i don't i live in my own house, i live on a air force base in the dorms), buy a car cover...that will help out alot...
phil
Old May 27, 2003
Voiceofid's Avatar
End Bringer
the spring, grey made them, he made 2 and sold one to me, and used one for himself (that reminded me grey, want that feedback? LOL)
it was a softer spring than the factory latch spring, and it was very easy to replace. before i brought the spring from him, i would have to actualyl push very hard to close the hood, infact i won't be successful most of the time, after i got the spring, it became easier, and i also moved the latch a tad up. i think you might have to remove the front bumper tor each the 2 bolds holding the latch onto the engine bay
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
Mc7602
Sep 17, 2015 02:01 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
