jack up car for diy rear anti-sway bar?
Old Apr 27, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
do u have to jack up the car or put it on jack stands or a lift or whatever if u install the rsx rear anti-sway bar. i searched and found diy's that have the car on jack stands. if i did it without lifting the car, would it cause any problems. do they lift the car to make it easier to work on or becasue u need to take the weight off the car when installing or swapping the anti-sway bar, thanks
Old Apr 27, 2003
Zzyzx's Avatar
Autocross Junky
If you jack up the car the suspension will uncompress, and caues the Anti-rollbars to go in to their "Loaded" position and they will be harder to remove and install. I would sugest that you jack up the car then Place some wood blocks under the wheels and drop the car back down on those. that way the car will be high enough to workon but the suspenson will be compresses, so the Anti-rollbars will be in their "Nutural"positon and be much easyer to work with.
Old Apr 28, 2003
thanks for the response, but i think i an work on it without the wood blocks, it doesnt look too hard
Old Apr 28, 2003
robbclark1's Avatar
Retired suspension supermod.
No it doesn't. Make sure you don't put it on upside down like I did!! haha. When you jack up the car and the bar isn't in "loaded position" it is hard to tell if it is the right way or the wrong way.
Old Apr 28, 2003
Zzyzx's Avatar
Autocross Junky
ya Robbclark is right. Sorry didint know what I was thinking. An Anti-rollbar goes in to the Loaded position when one side compresses/decompresses. so if you were to try to jack up one side, and work on the bar, thats when the bar would be loaded and hard to work with. Every body gets to be wrong ocationally.
Old Apr 28, 2003
Grey's Avatar
DIY King
Yep, I concor. Whether the suspension is compressed or not doesn't affect the sway bar loading at all. It's only when one side is compressed more than the other does it matter. As long as both sides are even you're all set to install it whichever way pleases you.
Old Apr 28, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
It's easier if you take off the rear wheels IMO.
Old Apr 28, 2003
tekgnosis's Avatar
Ask me about your mom.
ok wait, I know I'm gonna f*ck this up when I install it.
which way is up?
Old Apr 28, 2003
Grey's Avatar
DIY King
The humo should face up. So... Hump instead of dip. Look at my pics. A pic of the Progress rear sway bar is in there.
Old Apr 28, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
lol, yea, don't install it upside down. It's easy to do.
Here's a pic of mine:
Old Apr 28, 2003
tekgnosis's Avatar
thanks guys
wait...I just took a look at it, and the left side looks to be almost shaped differently? maybe its my eyes and the time of night?
actually, no way, it does look a bit different. is this normal? should i take a pic of it?
man, it would suck if it's the wrong one
ok, i looked at the type S bar I have, and compared it to the type R bar I have, and they're the same shape.
I'm hoping that if the Type S fits, the Type R will as well
seems logical, but with my luck, you never know.
Old Apr 28, 2003
tekgnosis's Avatar
InanimateCarbonRod: d00d, you have an impact wrench?!?!
can I come over to your house to install this stuff?
hehehehe
jk
Old Apr 29, 2003
robbclark1's Avatar
Remember you need an allen wrench to get the bolts of the endlinks. Do you have a DIY for the bar? If not http://www.xenja.com/7thgencivic_RSX..._DIY/index.htm
Old Apr 30, 2003
yeah thanks a lot robblcark, i got that diy
bsmiley
Apr 27, 2015 01:27 PM
zcwagon
Apr 24, 2015 05:18 PM
CivicVoz
Apr 16, 2015 08:07 PM
ej8
Apr 13, 2015 06:36 PM
2Hondaz
Nov 8, 2001 11:00 AM
